Question about Brother IntelliFAX 3800 Plain Paper Laser Fax
Our IntelliFax 3800 makes squeaky noises when faxing out
We exclusively use this standalone fax machine for all fax receiving / sending at our the office. I do routine maintenance on the unit like cleaning the drum unit area, clean the printer, doc scanner, change the toner, etc. Lately, when we attempt to fax out, the paper goes thru but the machine makes squeaky noises like gears grinding at each other. It's not loud noises, but still noticeable. When I open the document scanner, everything looks normal and the rubber guides looks normal as well. When I hook it up to my laptop and print via USB connection, there are no noises, so I think the problem is just the doc scan area.  Is there anything I can do to stop the noises like oiling it? Thanks for your prompt assistance.
AJ
  • 1 more comment
  • theb8er Oct 26, 2007
    Brother Intellifax 3800
  • theb8er Oct 27, 2007
    Thanks for your help! Where do I get the rollers? Is this a DIY type of project?
  • theb8er Oct 30, 2007
    Thanks!
    Scholar:
  • 121 Answers
You'll need to replace the pickup roller.
Posted on Oct 27, 2007
  • Eric Engel Oct 28, 2007
    I'll have to wait till Monday and get the part # for you.  You'll probably be able to order it from some local dealer.
  • Eric Engel Oct 30, 2007
    Here's the number:
    LE1816001
    Here's the directions for replacing it:
    4-21
    4.1.9 Document Feed Roller ASSY, Scanner Drive Unit, and Document Ejection Roller ASSY
    (1) At the right end of the document feed roller ASSY, unlock the pawled bushing and pull it to
    the left. Then remove the document feed roller ASSY together with the pawled bushing.
    (2) At the right end of the pressure roller shaft, press the latch to the rear and take out the pressure
    rollers and their shaft. Then remove the pressure roller springs.
    (3) Remove the two screws from the scanner drive unit.
    (4) Lift up the scanner drive unit together with the document ejection roller ASSY. The bushing
    also comes off.
    4-22
    (5) Remove the screw from the scanner motor and take off the motor from the scanner drive unit.
    LE1816001
    4-21
    also comes off.
    4-22
Brother Intellifax-2820, will not print incoming faxes. It rings, says it's receiving data and thats it. Yes I have paper in tray. Sends and copies fine.
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Oct 04, 2009 | Brother IntelliFax-2820 Laser Fax
Our Brother Intellifax 3800 will go to sleep and ignore attempts to send or receive faxes. It will take a docment into memory and go to sleep and not send it or the phone will ring with an incoming fax and...
i don't have the owners manual handy, but i'm quite sure you can disable the sleep mode by pressing a couples of buttons on control panel. that procedure is in your owners manual on the same page as setting sleep time.
hth,
razors
Mar 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Not pausing to acknowledge
Open up the feeder to see if a piece of paper is holding a switch actuator down.
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Cannot receive fax on a Brother Intellifax 885MC
make sure your receive mode is set to "auto" or "fax only". if thats not it, you may have a phone line problem. i have seen that before.
hth,
razors
Jan 12, 2009 | Brother IntelliFAX 2800 Laser Fax
Won't receive faxes
Make sure the receive faxes button is set properly. If it is not set to fax only, you will need to manually receive faxes, the machine will not auto answer.
Dec 11, 2008 | Brother IntelliFAX 2800 Laser Fax
Can't recieve a fax.
Unplug power cord. Plug back in. Call your fax machine from cell phone and listen for fax tones.
Sep 17, 2008 | Brother IntelliFAX 3800 Plain Paper Laser...
Super G3 brother IntelliFax 3800
Sounds as if the tel line is not connected. 1st check with a telephone, see if you get a dial tone. If not then call the tel company
Mar 07, 2008 | Brother IntelliFAX 3800 Plain Paper Laser...
Brother IntelliFax 4100 sending solid black pages
It sounds like the CIS (scanner) has failed in both machines. Its no generally not a common problem. I would change one every six months if I was lucky.
It may point to something in your environment. I have have seen rust build up on the contacts of the scanner cause this problem. So if you have high moisture or are close to the ocean this maybe a problem.
Feb 14, 2008 | Office Equipment & Supplies
Can't receive fax
Pick up the receiver and see if you hear a fax tone noise. If so then push the start button and hang up. Is this machine on a dedicated line or shared with the main phone number? Sometimes some people will pick up the receiver on their fax machine dial the fax number and wait for a tone before sending. If this is the case the machine can not recognize that is a ax. Make sure your machine is set for auto receive if it is on a dedicated line.
Apr 06, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 3800 Plain Paper Laser Fax Logo
586 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
