Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
U3 Run for about 3 minutes then shows u3 code
  • Fisher and P... Master
  • 3,247 Answers
The dishwasher is filling up too quickly compared to what the controller expects. Try to turn down the water inlet tap under kitchen sink and check. Also see if the water pressure setting in the dishwasher is HP for normal mains water pressure. See
DD603 U3 fault code
Posted on Feb 11, 2014
Meaning of u3-3 in 428
http://www.omkarmin.com/pdf/workcentre-pro-423-428-printertec-23924.pdf
U3-3
(4133)
ROS failure
Abnormal power adjustment
value to the laser diode
when the diode is forced to
go on
POWER
OFF/ON
Jun 07, 2014 | Xerox WorkCentre Pro 428 Copier
Tip
How to reinstall U3 ScanDisk Application
<p>The U3 Launchpad is a suite of tools useful for portable programs to run and install from a SanDisk flash drive. Many SanDisk flash drives come preinstalled with the U3 Launchpad to install them. Some users find this suite to handle, while others have claimed that the opt-room suite takes on their journey. With a small amount of installation and configuration, the units that previously praised the SanDisk U3 Launchpad can begin again. <br /> <p> <br /> <p>1. Connect the SanDisk flash drive into a USB port and drag all your important data to a folder on the desktop. Backing up data is essential, since the re-install the U3 software to reformat the flash drive to delete all data. <br /> <p><br /> <p>2. Download the U3 Launchpad Installer (only a Google search). <br /> <p><br /> <p>3. Double-click the resulting file to the U3 Launchpad Installer<br /> <p>LPInstaller.exe run. Go to the installer, "Accept", select the software license agreement. <br /> <p><br /> <p>4. Choose Save and restore all data "if you drive with the backup job to complete for you. Otherwise, select" No, no backup ...." <br /> <p><br /> <p>5. Click Finish when the installation is complete. <br />
on Jun 22, 2011 | Computers & Internet
My flash drive 16 gb sandisk cruzer u3. when i insert in Laptop it opens but file not showing. showing run launchu3.exe. how can i get launchu3.exe? i checked prpperties all file inside but not...
I have the very same flash drive.
The file you refer to "launck3.exe" is a file compression utility from Sandisk. It works well but I don't use it. I placed the drive into a USB slot and chose "open folder" in the options not "auto run". I then mad a new folder called "old cruzer" and moved all of the files in the root of the flash drive, to it. Leaving an nice empty drive to copy and paste to.
I hope that helps.
Oct 22, 2010 | Computers & Internet
U3 error code
I believe U3 error on your model of dishwasher could also mean a couple of other things like either the drain hose has an obstruction (kink) or the inlet water pressure is not correct.
Hope this helps in finding out what could be the actual reason. T
o find the kink if any, pull the drawer out as much as possible and feel the hose. Might be better if you took the bottom drawer out from the casing and inspect the hose completely. As the problem is limited to upper drawer you do not have to worry about what is under the bottom drawer. Check the water pressure setting is same for both drawers. If so then that is not an issue as bottom drawer is working ok according to your description. See your manual for instruction on how to check the water supply pressure setting on your dishwasher.
Jun 13, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
How to download softwares to my sandisk u3 flashdrive
As you may know your U3 Smart drive has a small OS that allows you to run Your applications on another computer. This OS shows as a CD-ROM icon on which you click to execute the LaunchPad (TheOS) of the Cruzer. In addition to that you have the icon of a regular drive. (Usually the Drive letters are consecutive G and H for exemple.) When you safely remove one both are unmounted at the same time.
Once the LaunchPad has been executed, it installs an icon on the sys-tray. When clicked, that tray icon opens a pop Up window, giving a menu of the applications installed and which you can run on the host computer, but from your drive (U3 Smart Programs on the left) and on the right various menu options
  1. to explore the drive,
  2. configure the drive(settings),
  3. add programs (to download additional U3 programs),
  4. and enable security. etc.
So if you want to download additional U3 Programs to run from you drive you use the Add programs (option 3 in the list above)
However, if you just want to put regular files on the drive (pictures, text documents, etc.) you do as you woul for nay drive: You drag and drop the files, not on the CD-ROM icon, but on the other drive. You can also use the Explore option (option 1 in the list above) to open the second drive to see what is in it, add files, remove files etc.
Hope it helps
Nov 10, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Top drawer works but bottom drawer shows code u3 and bottom drawer started leaking water before the u3 code showed up
U3 code generally relates to drain pump blocked. This could mean the water is not able to drain out. Leaking of water is not a good sign. Shows the vacuum seal is not working.
Clean the drawer door from inside and make sure the seal lining is sitting properly. Also the filter plate and the motor cavity needs cleaning. You will need to see the user guide on how to do this.
Nov 02, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
U3 fault code
http://d.scribd.com/docs/1nt2h7ei2nuuw9vihz41.pdf
Jan 16, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Lost space in my Sandisk Cruzer
I had the same problem. Just go to Sandisk's website and download the latest U3 removal tool, run it and it will format it back to 7.5 GB.
Oct 14, 2008 | Electronics - Others
DD601ver2
check for restriction in sump. ie remove rotor, push pipe cleaner or similar from filter sump into rotor sump
Jun 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
100 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
