Question about Xerox Phaser 8550DP Printer
7.010.43 problem with Xerox Phaser 8550
My printer shows the 7.010.43 error. Upon dissassembly, the problem was obvious: the whole Process Drive fell off as the black plastic headers holding the drive in place snapped. This also explains the error as the Service Manual lists Process Drive malfunction as one of the possible cases for this error (see page 3-19) Any idea how to fix this? I was thinking about drilling some holes into the printer's frame and use some longer screws to fix the process drive in place. That, plus some epoxy resin should do the trick. However, the frame appears to be made from some sort of black plastic thta chips off easily so I'm a bit worried. No idea about its machinability ... anyone attempted a fix like this?
  • 2 more comments
  • Adi Oltean
    Adi Oltean Feb 10, 2014
    Another idea could be to use some strong epoxy resin to fix the black plastic in place. I feel a bit uneasy about this as well as I am afraid that the epoxy might not be strong enough ...
  • Adi Oltean
  • Adi Oltean
    I added two pictures ... (sorry for the duplicated message earlier - not sure why was added twice?)
  • Adi Oltean
    Thanks for your reply. But the part being broken is the whole printer frame, meaning replacing the whole printer. Not sure if it's worth it ...
    Problem Solver:
  • 12 Answers
Hi there, Love your enthusiasm to fix it - probably very similar to me. But I think you'd be better suited finding a replacement part and buying that, then replacing with an original. I'm not sure what part of the world you're in, but there will be xerox service centres around. Or you could call-up a local printer repairer and ask them to get you the part. Otherwise you just start opening a can of worms when you start gluing it in - then there's a potential that it doesn't hold properly and next thing you're having the same problem again. Alternately - try to pick up a used printer on ebay or similar of the same model that is broken or for parts and hope that they don't have the same problem.
Posted on Feb 10, 2014
  • Adi Oltean
    Thanks - the problem is that the broken part is the whole printer frame, meaning that I need another printer. The printer I have is second-hand anyway ...
  • Adi Oltean
    Adi Oltean Feb 14, 2014
    Good news - my expoy-based fix worked! I used the J-B Weld steel reinforced (3960 psi) which proved enough to fix the plastic headers back on the frame, plus an extra screw I added to hold the Process Drive in place
3 Suggested Answers
  • 81 Answers
SOURCE: phaser 8550 error 19,004.40
The printhead was installed in another machine and the codes do not match. You need to manually sync them. Here is the procedure:
Manually synchronize the Printhead and Electronics Module codes.
NOTE: The Printhead and Electronics Module codes should synchronize automatically when a new printhead is installed. If a 19,004.40 error occurs, it is possible that the replacement printhead was previously installed in a different printer. After manually synchronizing the Printhead and Electronics Module codes, be sure to test the new printhead for print quality defects.
To manually synchronize the codes;
1). Power OFF the printer.
2). Disconnect the printer from external devices (A/C power can remain connected).
3). Locate the "Factory Only" port on the electronics module (located between the PS and PE lights (Figure 1).
4). Use a Hard Disk Drive (HDD) jumper (Figure 2) to short the top two pins.
NOTE - If a HDD jumper is not available, use another conductive item, such as a screwdriver, to short the pins. Use caution to avoid contacting the surrounding frame, as this may permanently damage the Electronics Module.
5). With pins shorted, power ON the printer.
6). When printer reaches the mechanical initialization stage of the power on sequence, power the machine back OFF.
7). Remove the HDD jumper.
8). Code should now be synchronized. Power ON machine and verify the 19,004.40 error does not re-occur.
NOTE - If error persists after this procedure, attempt the procedure again, and be sure to allow the printer to complete its BIST and POST test before powering OFF in step 6.
Posted on Jul 23, 2008
  • 2072 Answers
SOURCE: XEROX 8550 DP ERROR Message 09,035,43; 10192
That is a cyan, ( blue) ink stick fault. What is happening is that the cyan ink sticks are not advancing down the ink loader properly.
Open the area where you load the ink and you probably have a cracked, twisted or otherwise stuck ink stick, the code you are reporting specifically refers to the cyan sticks. If you have to remove them, take a screw, a drywall screw is best, and twist it into the sticks and slide it back and out, then replace them or add new ones. But thats your problem.
Posted on Oct 29, 2008
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
  1. Make sure you are using Phaser 8500 ink sticks
  2. Make sure the ink sticks slide properly
  3. Remove any broken or partial ink sticks from the ink-loading bin
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at www.xerox.com\support
Oct 24, 2009 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8550 Maintenace Kit is stuck in the
If you remove the right side cover, you can operate the process drive gearbox with a straight-blade screwdriver on the end of the shaft (bottom of printer right in front of maintenance kit). This is the end of the drum maintenance camshaft. Rotate clockwise slowly. It's possible that the cams have cracked and rotated on the shaft. This is the weak point on these printers. If so, they may not be in sync. Good luck.
Jul 13, 2009 | Xerox Phaser 8550DP Printer
Phaser 8550 . what does printer error code 09,005.40:78005 mean?
9,0XX.xx Errors - Ink Loader Faults. Try switching the ink loader.
Jul 08, 2009 | Xerox Phaser 8550/DP Thermal Printer
Printer Phaser 8400 : error 07,010.43:116034
If your printer is networked, if can fix its self by accessing this site
http://www.phasersmart.com/
May 18, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8550 printer error 09,037,45:23780
This means the Yellow ink sticks are jammed in the machine, open up the top of the machine and check if the sticks can slide freely up and down and remove any broken sticks.
Niallbt
Mar 31, 2009 | Xerox Phaser 8550DP Printer
Xerox 8550 Error message 19,003.48:121016
19,003.48 Scale and offset voltage error too large. Something is wrong with the Electronics Module or Wave Amplifier.
that is pretty straight forward. More then likely the elsctronics module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Check @ 1-800-835-6100 to see if you are under warranty or have coverage.
Apr 22, 2008 | Xerox Phaser 8550DX Laser Printer
Phaser 8550 cyan doesn't print
If you go to the Xerox.com site and click support and drivers. enter phaser 8550 and there is a printhead update you need to get, You have to fill out a form.
That may be your problem since there is no fault code.
Apr 13, 2008 | Xerox Phaser 8550DX Laser Printer
Error code for 8550
Call Xerox, they have a problem with this code and the ink loader needs to be updated.
It has to do with the yellow sicks loading properly
Oct 31, 2007 | Xerox Phaser 8550DX Laser Printer
Xerox Phaser 8550DP Printer Logo
162 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
