Question about Kodak EasyShare C633 Digital Camera
Easyshare1530 with no disc? - Kodak EasyShare C633 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo management program such as Picasa ( http://picasa.google.com ).
Posted on Feb 10, 2014
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
Why does the disc reader say "no disc" after I put one in? It played earlier
Not all disc are equal.
Try a different disc. Some machines can be fussy about certain discs. Sometimes the disc itself can be kerfluewy, so try the disc in a different machine, too.
Mar 24, 2015 | Televison & Video
Disc keeps getting rejected
see the cause and remedies and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
see the block d. attached.
Jul 20, 2012 | Televison & Video
Sony GDP s301 won't play any discs
see the cause and remedies:
Does not play disc
Finally the OPU, optical pickup unit contain too the lasser beam, NOT are reading the TOC of disk,+Syscon can be defective. You must go to the repair shop TV for fix it. this a complex equipment.
see tje block diagram.
God bless you
Jul 15, 2012 | Sony BDP-S300 Blu-Ray Disc Player
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
My Xbox 360 keeps scratching my game discs?
Sounds like the xbox console needs the laser adjusted or secured as per the other comments. For any discs issues, read on.
Check to see if there are any scratches or laser burn marks on the discs.Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that XBOX owners are reporting is; if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc. This occurs to discs when the games console has been moved whilst playing. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on XBOX disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the "More Info" & "FAQ" Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the disc is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Apr 07, 2010 | Microsoft Xbox 360 Console
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Playing new fifa2010 on x boxx 360. working ok and then froze stating ''clean with soft cloth'' tried this but unsuccessful
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render the game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error”. Best remedy for starters is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but professional disc repair services is normally rerquired to restore disc laser burn damage back to "As Good As New Condition".
For further help on Xbox & Xbox 360 disc repairs or to get discs professionally repaired, visit:
www.discREPAIR.ie
Check the More Info Section & FAQ section for more details on disc repairs.
Send your discs off to this Disc Repair Service and the discs shall be sent back as good as new.
Dec 26, 2009 | Video Game Consoles & Games
The recorder will not record on a brand new panasonic disc but will continue to record on my older disc.The panasonic dealer insists there is nothing wrong with the disc.Went into 'disc management' on the...
Yes,
In the Disc Management options you should have the option to change whether disc protection is on or off.
Also, if you have one of the double-sided discs - they look like large computer floppy discs and can be inserted either way up into the machine - some of these have a "write protect" tab just like a floppy disc. Check to see if yours has one and whether it is set in the protect position.
Oct 15, 2009 | Panasonic DMR-E55 DVD Recorder
Drive can not read CDs..read Dvds
I suppose that you have windows XP. Pls follow these steps Clean the disc - Clean the disc with a disc cleaning kit or by gently wiping the silver side of the disc from the center outward with a dry, soft, lint-free, cotton cloth. Check the disc for damage - Remove the disc from the drive, and then examine the disc for scratches or cracks. Try a different disc drive - If the computer has more than one disc drive, insert the disc in a different CD or DVD drive to see whether it can read the disc. If your computer does not have more than one disc drive, you can insert the disc in a different computer. Make sure that the disc is compatible with the drive -Check the following list to make sure that the disc that you are trying to use is compatible with your CD or DVD drive.
  • A DVD disc is incompatible with a standard CD drive.
  • A CD-RW disc is incompatible with a CD drive that does not support CD-RW discs.
  • A DVD disc is incompatible with a drive that does not have a DVD logo on the front.
Use Windows Update to check for updated drivers - If the disc is compatible with your CD or DVD drive, check for updated drivers that the CD or DVD drive may be missing. To check for driver updates that you can install, visit the following Microsoft Web site: http://windowsupdate.microsoft.comRegards
Jun 18, 2009 | Computers & Internet
Kodak EasyShare  C633 Digital Camera Logo
16 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
