Question about Beyond Cell Phones
How to connect a mt65x to computer by usb.
Samsung version of mt65xx i purchase is with mediatek software and i can not connect to usb cable
SOURCE: Need to transfer photos from Samsung Sync phone to PC with Windows Professional
i have samsung model E600 cellular phone need to transfer photos to pc , have a usb connection, but cannot transfer photo to pc my computer recognize it as unknown
Posted on Mar 17, 2008
SOURCE: SAMSUNG G600 USB CONNECTION PROBLEM
What you have to do to put files on your computer or take them from your computer onto your phone is: go onto settings, onto phone settings, onto USB settings and chage it to either mass storage (if you want to put pictures, music and videos on) or media player (to just transfer music). Then plug in the USB cable that came with your phone into your computer/laptop and follow the instructions from there.
NOTE: This only works with the Sampsung G600
Posted on Jun 10, 2008
check Bit Pim at www.bitpim.org, I have the same cell phone but I don't have the usb cable.
Good luck.
Posted on Jul 29, 2008
SOURCE: I have a MotorolaQ and
Same here. Just got it from a friend.
Rob
Posted on Nov 20, 2008
SOURCE: Cant connect to computer via USB connection. Software wont open or reads no phone connected.
You probably have the USB selection set incorrectly on the phone. Go to Menu, then Connectivity, then USB, then select "Data Service". The should fix it.
Posted on Jun 09, 2009
How do I get pictures from my Samsung Galaxy j7 sky onto my computer?
If you need to transfer photos from Samsung phone to computer, the most efficient solution is to use a helpful data assistant software.
You don't need to transfer photos one by one, it can save you a lot time on this thing. So, it is very effective for you to transfer photos between Samsung phone and computer.
Transfer Photos Between Samsung Phone and Computer
Aug 04, 2017 | Samsung Cell Phones
How do i transfer photos from phone to laptop without it transfering all my files
Connect your usb cable to your laptop and a popup dialog box should appear asking what you want to do with the device, choose open folder to view files. If a popup does not appear go to Computer or My Computer and you should see the phone as a storage device, double click it and you should see all kinds of folders in there. You are concerned with pics so focus your attention on a folder named DCIM...
Navigate to DCIM and open that folder, this is the folder that contains your pictures. Press the control (CTRL) key and select the pictures you want by left clicking each picture one time or go to the top of the DCIM folder and click EDIT > Select All, once the pics are highlighted make sure your mouse cursor is over any one of the highlighted pics right click the mouse and select copy or cut, (cut will remove the pics from the phone , copy will do just that, copy), navigate to where you want to put the pics and open that folder, right click on an open area within that folder and left click Paste from the popup menu.
That's it.
Jun 03, 2014 | Samsung Galaxy S GTI9000 Smartphone
Where do I get Windows CE 6.0 drivers for RALink 5370 USB WiFi Adapter?
There are no drivers for the RALink 5370 for Windows CE. This product's Windows support starts with Windows XP. You need to try a different wireless adapter. One rated for WinCE.
May 29, 2014 | Ralink Technology, Inc. Computers &...
I cannot install the above mentioned scanner since the driver is unspecified
IF IT IS USB BARCODE SCANNER, DO THESE:
1.
Locate the USB connector on the bar code scanner. Bar code scanners, like other computer peripherals, connect to the computer by way of a data cable. At the end of the data cable, most likely opposite the scanner itself, should be a small rectangle-shaped plastic and metal connector. This connector is the USB terminal that will plug in to the computer's USB port.
2.
Locate the USB port on the computer. The USB port, whether on the computer or a peripheral device, will be rectangular in shape and feature either the letters "U S B" or a small network diagram showing two circles, a square, and an arrow.
3.
Connect the USB cable to the computer or peripheral device. Once the USB connector and port have been identified, push the USB connector firmly but gently into the available USB port. USB connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the USB connector, remove the connector from the port, turn it over and plug it in.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must decipher the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
TO INSTALL A SERIAL BAR CODE SCANNER, DO THESE:
1.
Locate the serial connector on the bar code scanner. Bar code scanners, like other peripherals, connect to the computer by way of a data cable. At the end of the serial cable should be a rectangular, typically male connector. The cable may be pinned with nine, sixteen, or more pins depending on the design of the scanner.
2.
Locate the serial port on the computer. Most computers have at least one serial port, usually found on the back of the machine. The port will be female, maybe blue in color, rectangular in shape, and should be approximately the same size (or slightly smaller) as the serial connector.
3.
Connect the serial cable to the computer or connected peripheral. When both the connector and port have been identified, push the serial connector firmly but gently into the port. Like USB connectors, serial connectors are keyed so that they can only be inserted the correct way; if you feel solid resistance while inserting the connector, remove the connector from the port, turn it over and plug it in. Do not use excessive force while pushing on the serial connector, as it is possible to bend the connecting pins and damage the connector.
4.
Install bar-code reading software. While the bar code scanner can scan the bar code into the machine, software must interpret the meaning of the code. Bar code scanners, if purchased new, should include a version of proprietary bar code software compatible with your specific scanner. If your scanner did not come with software, or if it is missing the installation disc, bar code software may be purchased on the Internet from sites like WaspBarcode.com.
THANKS AND WELCOME.
Apr 12, 2011 | Computers & Internet
It is the notepad version that has no disk drive, so how can I install a cam?
If your computer does not have a CD drive then -
There are two methods.
1. Purchase or borrow an USB external CD/DVD drive connect it to the notepad's USB port and install the software from this drive.
2. Use a different computer and copy the contents of the CD to an USB memory stick and then plug it into the notepad's USB port and install the software from this USB memory stick.
Mar 26, 2010 | Samsung NC10-14GW Notebook
Bose Remote not linking to Samsung HDTV
I got my bose remote to work when I did a system update on the remote. Turn the TV on. Select the TV video input that connects the system. On the control console, press and hold setup until the system information screen displays. line 5 will display the currently installed console software version. on the remote press any button. Line 10 will display the currently installed remote software version. Do a bose system update. On the control console press setup. on the remote control, press the down arrow until update is highlighted and press ok. make sure yes is highlighed and press ok. on the control console plug a clean usb drive into the usb port.when prompted, remove the usb drive and connect it to a computer. open the drive and double click on the download_launcher file, which should bring you to an update page on bose.com. Once complete, put it back in the control console. When the update is complete remove the usb.
Feb 22, 2009 | Bose RC-28S stereo expansion kit - White...
I have just recently purchased a Samsung SHB J700, and have just installed the PC programe. I have checked that the software it up to dtae. But when trying to sync the phone to the PC, the USB connection...
after you've installed the samsung software and driver,
plug the USB cable for your phone into the BACK of your PC (or a "USB2 slot"), your computer should detect the device properly now.
the USB ports at the front often are not USB2 ports (or aren't configured properly).
this is worth a try before contacting samsung for support.
Aug 06, 2008 | Samsung Cell Phones
D900i
try removing then reloading software for the studio (ensureing it's the right version for the phone) check your usb cable works on both phone and pc end. you should be able to go into file and then CONNECT and it should allow you to connect with your phone automatically then follow the menus. To move stuff to PC click TO  PC option and visa vers for stuff on your computer. 'Drag and drop' should also work with this.
Is you computer bluetooth? if not try buying a bluetooth dongle and software from samsung direct and try loading that.
Hope this helps
Oct 13, 2007 | Samsung SGH-D900 Cellular Phone
Sep 15, 2007 | Nokia 6233 Cellular Phone
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cell Phones Logo
116 people viewed this question
Top Beyond Cell Phones Experts
Techplus 2008
Tom Chichester
ray gallant
Are you a Beyond Cell Phone Expert? Answer questions, earn points and help others
