Question about Konica Minolta DiMAGE E500 Digital Camera
LCD Black I went to turn on my camera and everything turned on normally( shutter opened). When we lookied at the LCD screen it is black but the icons show up. We can change setting. If you take a picture the way it is now the picture turns out black. I cannot see any images in the LCD at all. All pictures taken now are black.
  • 2 more comments
  • jgohawthorne Nov 02, 2007
    I have the same problem. with my Konica Minolta Dimage X20 All functions seems ok. You can use the playback very well except for the black LCD and viewfinder wherein no pictures can anymore be taken. Pls. notify me for any solution to this problem. or email me at jgohawthorne@aol.com. Thanks
    Jimmy
  • sweetnlovely Sep 05, 2008
    I have the same problem. Can I fix it? Is it just a small problem? A setting or something?
  • cold up nort Oct 02, 2008
    hi ya, i also have had same problem so i contacted them and they say it is known hardware fault(ccd) but refuse to fix it, unless you pay £89.00. this has to be sent to one specialist repairer in newcastle under lyme and the postal charges are a lot too with 3/4 weeks till you get it back. dont touch this camera and dont buy anything from them their attitude sucks, seems they quick enough to take your money but not quick on customer service.
  • tenborsid Mar 23, 2009
    Exactly the same problem. Looks like it is a known fault. Has anybody found a way around it?
Swith off the Camera and gently tap the bottom(tripod hole side) to a hard surface, I was lucky and it worked for me for the same kind of problem.
Posted on Jan 12, 2009
    Genius:
  • 2,985 Answers
Contact Damage support - there appears to be a problem with this model
http://www.google.co.uk/url?sa=t&ct=res&cd=1&url=http%3A%2F%2Fca.konicaminolta.com%2F&ei=bzOwSMj2CYreQd-i-Gg&usg=AFQjCNEEQPR1zDRvdYe3DCF0EhXowwYetw&sig2=AAutefCXmdjtFGCFF7XjRg
Posted on Aug 23, 2008
2 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: LCD is black
you can see images clearly? but no Menu items show is that what you mean? This would indicate a firmware malfunction. If you see nothing at all on the screen but only 'ghost' images then the back light has blown. Try first of all with the camera on tapping gently at the base of the casing in the region of the screen- this is where the connectors to the main board are. Contact The Minolta support team. If you are getting nowhere - I suggest the next camera - repairs are not usually an economic option if at all.
Posted on Jun 27, 2007
When trying to take a pic, I only get a black LCD screen. I can see the icons and I can play pictures back on the review mode. Any idea what's wrong? Thanks!
Try pressing the DISP button on the back of your camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place to save batteries.
That normally fixes the problem of a black screen, but if it didn't, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 02, 2010 | Canon PowerShot SX110 IS Digital Camera
My LCD screen is black. The camera seems to take
its actually probably the display. there is 3 different displays. 1. shows picture with icons 2. shows just the picture and 3. is a solid black screen. just hit the display button to cycle through until your desired display is present
Feb 07, 2010 | Canon PowerShot A620 Digital Camera
LCD screen is black-cannot take photos
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 16, 2009 | Kodak EasyShare CX7330 Digital Camera
Black lcd screen on Ixus 70 shows icons but will not take picture
Jun 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Hey, I just purchased a Canon Powershot A720 IS today and as I was messing with it the LCD screen just went black. The icons on it show up, but when I take a picture its just black, as if the shutter isn't...
First turn on the camera and press the DISP button on the back of the camera (lower left corner). The DISP button manually turns the screen on and off to save batteries. But if that doesn't fix it, then take the camera back for exchange. Black pictures are usually indicative of a defective CCD imager, and hence a defective camera. You can't fix this yourself.
Jun 28, 2008 | Canon Cameras
My lcd screen is black
hi there guys, if the screen is black and the camera takes black pictures, then you should look if you are getting a on screen display on camera mode. if you are then i would say one of two things, either the shutter is not opening or the ccd( electronic imaging device) is not functioning. to check the shutter you should look into the lenses centre part and check for movement from the shutter to see if it is opening.
Jun 06, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Lcd just shows black images with icons
you need a new backlight or complete lcd replacement
I fix digital cameras call 214-650-6531 or email me at mike@digitalcamrepair.com
Dec 22, 2007 | Casio Exilim EX-S500 Digital Camera
Casio Exilim EX-S500 screen is black when turned on
you camera shutter is stuck at close position, you will need to open
the thing up to repair.
As for the totally dark screen, either your LCD or driver board is bad. You will need to open and replace the broken part.
Nov 15, 2007 | Casio Exilim EX-S500 Digital Camera
LCD is black
Jun 27, 2007 | Konica Minolta DiMAGE E500 Digital Camera
Black Lcd and pictures.
The problem you are experiencing is due to the shutter being stuck closed. Normally the shutter is kept open while you compose the image, and then when you push the button it closes and the CCD records what it was seeing at that moment. When the shutter is stuck the image is blocked from reaching the CCD at all times so you can see nothing. Unfortunately the shutter is a tiny delicate component buried deep within the lens assembly and is not accessible without complete disassembly. I would suggest finding a repair center to ship the camera to, or replacing the camera. I would definitely not _gently_ tap the camera on a hard surface to possibly dislodge a slightly stuck shutter blade. This could easily cause further damage to the camera. However, you are not me. ;) David Millier Advance Camera Repair
Feb 22, 2007 | Nikon Coolpix S1 Digital Camera
Konica Minolta DiMAGE E500 Digital Camera Logo
171 people viewed this question
Top Konica Minolta Cameras Experts
Computer Links
Steven Wander
Steven Wander
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
