Question about Canon PIXMA Office Equipment & Supplies
How to set canon mp 287 paper size a4 - PIXMA Canon Office Equipment & Supplies
SOURCE: have canon mf5700 says check paper size and only prints one page of several page job
If your alarm light is flashing and your printer will not print, press the "copy" button to get the device into the copy mode, once the copy button light is on, press the "Status Monitor" button. The LED panel will then show two lines of words: Line 1 "COPY STATUS" and Line 2 "SELECT JOB TO CANCEL"; then hit the Set button and the screen will show you what print job which has jammed the printer and you then press the - (Minus) button to clear the job. Open and close the front panel and the printer should reset and the warning light go off.
I had trouble locating the problem because my machine tends to stay on the Fax mode and when I pushed the Status Monitor button I would only get information about fax jobs.
Hope you have already figured out the problem. I thought I had better tell someone so I will remember the next time I try to print a job which requires a different size paper than what I have in my printer.
Blessings!
tdocdaws
Posted on Jan 12, 2008
  • 40 Answers
SOURCE: hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Posted on Jul 27, 2009
iservice
  • 318 Answers
SOURCE: I have a Canon Image runner 1023. when I print i
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Posted on Dec 09, 2009
  • 4090 Answers
SOURCE: Canon Pixma MP500 Reset PAGE SIZE to A4
Set up the parameters you want A4 Paper orientation etc then go to profiles in printing prefences and ADD to profile.. delete any others that preced this set of parameters
Please tae my help++++Thanks for using FIXYA
Posted on May 09, 2010
SOURCE: printer asking me to Load MP Feeder with A4 - the
factory reset should fix it unless the paper size ciruit board and levers have been physically damaged (back left on the printer in paper tray slot)
Posted on Jun 10, 2010
Load A4 paper in the multi-purpose tray again,and then press [paper] to print. error shown in LBP2900B
If you normally print on letter sized paper, then some program you are using is trying to print on A4 paper (PDF files often the culprit) and the default on most printers is that if they do not have the paper loaded it will ask for it from the MP tray. You can check your printer settings as you may be able to tell the printer to automatically sub letter paper when A4 is requested.
Sep 20, 2015 | Canon LBP2900
MF4350d 1page only
You must check the paper settings, Canon MF 4350d have two trays, the Cassete/Drawer & MP tray or (Multi-purpose tray).
Go to Paper Settings found the panel of the Printer, Set Cassete tray as A4 or LTR size & MP Tray as Long size or Foolscap(FLSP).
You must go to Start>Devices and printers>Right click the Printer>Printer Properties>Preperences>Page size change to Letter>Apply and press Ok..
Make sure that everytime you print,it will match the paper size you want to able to use,..
Jun 07, 2014 | Canon ImageCLASS MF4350d Laser All-in-One ...
Load mp feader a4
Please determine what size you are trying to print (A4, Letter, Legal, etc.). The printer is requesting A4 sized paper in the maunal paper feeder becuase either you selected manual feed or the setting for the default try (usually tray 1) is not set to the correct paper size. In your case, make sure the green slide adjustment on tray 1 is set to A4.
Mar 22, 2014 | Lexmark T632 Laser Printer
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Saya punya masalah print cannon pixma MP 287 kertas gak bisa masuk pada saat diprint, kalau bisa kertasnya tergulung
I have a problem cannon Pixma MP 287 print paper can not enter when printed , if the paper can be rolled up
Dec 20, 2012 | Canon LASER SHOT LBP-2900 Printer
Printer asking me to Load MP Feeder with A4 - the
Feb 01, 2010 | Office Equipment & Supplies
I bought canon printer MF4150 from Singapore. The problem is when i print or photo copy A4 or legal size after 1 printer it errors and said load proper size @ MP tray
The printer may have a setup for a region which will change the paper size. Also the paper tray may need to have the paper size adjusted on it physically. Save the paper size in the preferences to A4.
Nov 17, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Canon pixma mp 780 message says:change paper to A4/letter/legal plain How do I do that??????
Go to Printer and Faxes in Control Panel, Right click on the printer for which you want to change the settings. click properties, go to printing preferences there look for paper size and select A4 or letter/legal as per your choice
Oct 01, 2009 | Canon Office Equipment & Supplies
CHECK PAPER SIZE
On the front panel:
Press the down arrow twice (Tray Menu)
Press the right arrow twice (MP tray size = C5)
Press either up or down button until display reads 'MP Tray Size = A4'
Press the start/stop button. Green light shows & A4 selected
(See pp 248 - 252 of the manual)
Dec 10, 2007 | Epson Aculaser C1100 Printer
old marine
old marine
