Question about Zanussi 24 in. DA6141 Built-in Dishwasher
Hello, my dish washer is a Zanussi DE 6844. Its problem is that when you turn it on, water dosen't pump in. What can i do to solve this problem
SOURCE: zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
The problem here is being caused by Blocked Filters in the Water suppoly In line/pipe. There are two(2) filters in this line, at the water connection point and at the Washer connect point(one at each end). If these filters become blocked, then the result will be a restricted water In-Flow and hence the Rinse & Hold Status. Disconnect the Water-Supply pipe and remove the plastic filters giving them a thorough cleaning before replacing them. All will be rectified by this action. Peter...
Posted on Mar 18, 2007
murdozzz2
  • 75 Answers
SOURCE: zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
Posted on Jan 11, 2008
SOURCE: zanussi aquaius DE 6855, starts
Either the exit hose does not reach a high enough point or the waste-pipe is blocked. I had this problem in both situations.
Posted on Sep 10, 2008
SOURCE: Zanussi DCE 5655 dish washer
There's a water leak inside, causing the anti[ flood micro switch to activate. Even a couple of tea spoonfuls of water will cause this. Remove the cover and check the polystyrene float at the bottom. A very small amount of water there will cause the problem. Check for any water leaks or even a slight water surge when the machine starts.
Posted on Aug 02, 2009
  • 574 Answers
SOURCE: Zanussi dish washer model zdt6255. About 5 years
More than likely its your heating element
Posted on Jan 08, 2010
Testimonial: "Thanks - I agree."
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Machine is locked with water inside
Are you getting an error code E20.because this would suggest a blockage in the pump/filter or drain.To get the water out there is a little hose down by the filter which pulls out a few inches and can be drained into a shallow dish,otherwise if you can get machine near the back door step undo the filter and let it drain outside,once drained get a torch and see if there is anything blocking the filter/pump.The end of the pump blade should be able to turn freely.Oh by the way once the water is out you should be able to open the door.Once you have done all before you put filter back in turn knob to spin or drain and you should see the pump spin.Now if all ok refit filter and check for leaks. Hope this was a help.
Good Luck.
May 01, 2010 | Zanussi ZWF1430W Front Load Washer
Dishwasher power there but wont fill up with water makes a slight buzz sound any ideas please ?? It's a Zanussi zdt6252 by the way..
The slight buzz is coming from the water inlet valve solinoid. It's OK.
But check whether water is getting into the inlet tube of the washer. Check the filter at the rear of the dish washer body wher the inlet tube from your water tap is connected.
Apr 05, 2010 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi dish washer problem no water
The machine goes on and makes the usual noises but no water is coming in. The water is on and the hose is fine. It is ZT685
Mar 21, 2010 | Zanussi Dishwashers
The Zanussi Aquapulse (de 6965) Fault Code AL3.
i have this now- another site suggested its the heater, or rater the circuit board. I have just taken it apart and have two dry solder points that are identified quire easily by soot around the area. so now off to find my soldering iron!!
Sep 26, 2009 | Zanussi 24 in. DE6965 Built-in Dishwasher
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
Zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Mar 22, 2008 | Dishwashers
Zanussi DE 6965
Hello Russel A L 6 Is Water Drain Time-Out Possible causes are; a) Domestic drain outlet unsuitable (obstructed) b) Motor faulty (pumps group/ drain impeller) c) Pressure switch faulty d) IWMS- Pressure switch tube obstructed e) IWMS- Sump vent hose obstructed f) Control board (Relay interrupt Regards David Marsh
Jun 04, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Zanussi zdt6252 stops on 'Rinse & Hold' midway thru Wash Cycle consistently...
Jan 02, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Zanussi 24 in. DA6141 Built-in Dishwasher Logo
53 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
