Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
How can I remove tannins from water
I am planning to use well water in my hot tub. But our well water contains tannins. What is the way to remove them from water.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 64 Answers
Tannins which is water that has organic material from decaying foliage can be a bit of an issue with your equipment especially the filters but for the most part is an aesthetic issue. The only way to remove the tannins is pre-filtering before you put the water in the hot tub. You can purchase a purestart pre-filter you attach to your hose when filling your hot tub. If that does not do the job there are some applications from MetalTrap that may aid you as well. If all else fails you may have to look into something more industrial like Tannin Filters Tannin Filter Systems Remove tannic acid color from well...
Posted on Apr 13, 2014
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
How do I get a stuck hot tub filter out
The best way to never having your hot tub filter getting stuck is.
  1. remove the hot tub filter monthly for a cleaning
  2. Only install the filter hand tight
  3. Replace your hot tub filter yearly
If your hot tub filter is stuck the best way to remove it is
  1. Turn off the hot tub power
  2. Use a strap wrench for leverage
  3. You may have to remove the water for better access
How to Remove Stuck Hot Tub Filter
Aug 03, 2014 | Viking Spas Comp. Pool and Spa Filter...
How to unfreeze a drain
all drains in a house contain an u trap. normal,{not in 2nd floor} cabinet drains can be cleared with hot water or best by inserting a common hair dryer into the drain on hot & running it for 30 min or so. for a frozen tub drain, remove all water and do the same. if frozen is on 2nd floor do the same as above, but with your thermostat set at 90 for 5 hours . if possible close off all areas to the offending freeze and the heat. the best way to plan for impeding freeze problems is to use the realtors choice of winterizing a vacant house, which is to use antifreeze coolent to block freezing of the u traps that hold water in order to stop sewer gases from entering the house .
Jan 06, 2014 | Plumbing
Nordic hot tub
All the plumbing on these items are accessed from the outside. You will have to remove the siding/skirt. Dont just cut a hole in it. Plan this out so that you can cover it with trim. You may end up making a large slice in the siding.
Nov 24, 2013 | Plumbing
Foul Odor
Odor from the water softening system can be attributed to several causes.
The best way to see if it is coming from the softener is to by-pass the softener and run the COLD water only for several minutes and see if the smell continues. Now run the HOT water and see if smell is coming from the water heater.
Some causes may be:
1. Hydrogen sulfide in the water supply (the water chemistry can change)
2. Sulfate reducing bacteria. Almost all water supplies have sulfates and if bacteria gets introduced into the plumbing system it acts with the sulfates to create sulfate reducing bacteria. Which creates a rotten egg smell in the water.
3. Salt additives can have many different affects on water chemistry and organics in the water causing musty, fishy, swampy type smells.
4. If you have a system for Tannins using salts with additives will always cause foul smells as it harms the Tannin media.
5. The ANODE rod in the water heater degrades and gives off a sulfur type, rotten egg smell.
RJ
Jul 22, 2010 | Culligan Under Sink Water Filter
Hi there, I have a Samsung top loader and have the same problem as many people out there. There are black small pieces of rubber like dirt after I do a wash. It sticks to the clothes and remains in the...
Surely you are in a better position to work this out than us! Try ising a hose with a rubber cup connection to fot to your tap.Perhaps even boild up a large container of hot water and carry it to the machine!
Thanks for using FIXYA
Jun 14, 2010 | Samsung SW62ASP Top Load Washer
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
HOT WATER WON'T FILL TUB
most inlet water hoses have screens in them.  You could remove the hose from the back of the washer and see if there is water flow.   If there isn't, the hot water valve assembly is defective.  These are solenoid operated valves that admit water into the tub.  They can be accessed behind the washer after you remove the back.
Mar 30, 2009 | Amana DLW330RA Top Load Washer
Leaking water from tub spout
First you should obtain a parts brake-down instruction sheet, contained within the owners manual or downloaded from the manufactures website. With that you will have a detailed description of the removal and re-installation of that units cartridge, which upon removal you may see a build up of debris at the inlet ports or a ruptured O-ring in need of replacement.
Before any dis-assembly, turn off the hot and cold supply to the unit.
Good luck
Aduz
Mar 27, 2009 | Home
Moen roman tub faucet on hot water side stops flowing and just trikles out
If this occurs after you were able to get hot water to flow from the hot side then I suspect that it is a piece of debriis that has found its way to block the port opening. Remove the acess panel to the valve shut the water supply off to the tub valve using the handles only first on the valve. With the access panel removed tak e a bucket or other similar container and remove the hot water tubing from the spout. Once that is accomplished stick the tube into the container and turn the hot lever on. This should blow out any debris that may exist. Reassemble the valvle. If this did not work remove both the cold and hot feed tubes from the spout and use an air compressor to blow the spout out. If neither of these worked you will probably need to call a serviceman to resolve as other options require cutting the hot supply to the handle and may require special tools that you may not have handy. Thanks for using Fix Ya.
Mar 03, 2009 | Moen Plumbing
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
112 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
