Question about Simpson Esprit 750 Top Load 7.5kg
Water drain out immediately while filling the washing machine
When i start the washing machine to wash, water come from the top and immediately the water drain out.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 40 Answers
You should check 2 things the drain pipe should be higher than the drum or there is some dirt in the thin pipe of the pressure switch try to blow air in it in order to clean it
Posted on Feb 10, 2014
5 Suggested Answers
SOURCE: WashMachine wont wash and wont stop filling
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
Posted on Feb 07, 2012
  • 713 Answers
SOURCE: My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Posted on Jul 14, 2012
  • 389 Answers
SOURCE: my washing machine Simpson Model no 22S711 wont turn off when it is filling up with water
if it stops when you turn the machine off the problem will be that the pressure switch chamber is blocked unblock it should be ok
Posted on Sep 30, 2012
richroth
  • 9472 Answers
SOURCE: my simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Posted on Dec 04, 2012
On Maytag top loader, water enters but drains immediately.
check that the drain hose is above tub level
check for faulty program board engaging the pump all the time
Sep 20, 2016 | Maytag PAV2300 Top Load Washer
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Kitchen sink hole fills up with water when using the washing machein
After washing cycle all the water flows immediately from tub to drain pipe. If the flow capacity of sink is slow sink hole fill up with water .
Connect washing machine drain to proper place for drainage.
Oct 05, 2013 | Washing Machines
The washing machine only keeps filling with water never stops
there is a water sensing device in your unit that is not working, it is located at the top end of a small plastic tube cumming from the washing drum the unit will have a number of wires going to the top or side of it and the plastic tube attached to the bottom, replace this unit
Apr 28, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore 80 series will not fill to wash - it starts to fill with water and then starts draining immediately??
If the washer drains immediately as it attempts to fill,or if it has problems with maintaining the water level after it does fill, this can commonly be caused by what is known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Read through the link provided and let me know if you have any questions. This could be a simple matter of drain hose placement. If this does not correct your problem, please let me know. I hope this helps you.
Oct 12, 2009 | Washing Machines
Washing machine tripping RCD
electrical short in m/c.could be heating element. regards
Jul 30, 2009 | Washing Machines
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Nov 30, 2007 | Maytag SAV5710 Top Load Washer
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Washer fills and drains repeatedly
Have a look at the routing of your drain hose. It sounds a bit as if: a. The highest point of the hose isn't high enough (you normally want to aim for about 3 feet off the ground) - so that water starts draining from the machine before it is finished filling. and b. There isn't an effective air break or anti-siphon valve where the drain hose goes into the domestic drainage system - so that once the machine starts to drain by itself, it continues until empty. A.
Jun 07, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
82 people viewed this question
Top Simpson Washing Machines Experts
Owen Barnes
Vernon Taylor
Are you a Simpson Washing Machine Expert? Answer questions, earn points and help others
