Question about Maxtor Ultra ATA/133 PCI Adapter Card (999812) IDE Controller
KSU DD15500 VLIDE
Need drivers
HOW COULD I RESET THE NEC SL100 PBX SYSTEM?
Download manual from: https://www.manualslib.com/manual/832824/Nec-Sl1000.html?page=531
System Reset on Page No. 2-509 of the manual:
Dial 1 + press HOLD (Press Hold key only to cancel)
Jul 04, 2013 | NEC PABX SL1000
I have 824 installed at my office, with three CO lines. All CO lines were working OK, but one out of them can not be selected now, and any body dialling from outside to that number gets a busy tone. In...
If the CO line works properly when disconnected from your system KSU, something in the KSU is keeping that line off-hook. If the trouble isn't caused by a phone that's holding the line, try resetting the KSU by shutting it off and unplugging it from the AC line. Reconnect the power and turn the system back on. This should clear up the problem if it was due to the controller being confused, which can sometimes happen. If the system picks the line again and holds it, check the phones for one with a stuck line select button. Then you'll need to have the KSU serviced if the trouble continues.
Apr 03, 2011 | Panasonic KX-TA824PK Phone
I have use llinksys PAP2T togather with Panasonic KX-T7730c. does it possible?
Gather what? A PAP2T is a 2-port FXS box. A 7730 is a phone that works on a Panasonic Key Service Unit. You can plug the CO lines of a KSU into the PAP box and the 7730 into the KSU and get dial tone on whatever line you used on the PAP if that's what you're asking.
Carl
Mar 24, 2011 | Panasonic KX-T7730 Corded Phone
The display on phone does not show who is calling, I have a vodiavi single line phone, we had a power surge and ever since then we cannot get the display to show up. The phone is several years old
I would try reseating the CPU card in the KSU. The KSU is the box that houses all of your electronics. Pull it out for two to three minutes then slide it back in the card slot.
Aug 14, 2009 | Vodavi Lands Phones
Manual and/or wiring diagram for Nortel's C6 CLID unit.
Hook up orange terminal screws to an available port on KSU
Loop lines from the telco to the first six pairs on the C6 then to the KSU trunk ports.
Software must be DR5 on KSIU to support caller ID.
May 03, 2009 | Lands Phones
NEED TO KNOWN WHICH NEC SYSTEM I HAVE
If your question is what specific system you have, it is the NEC Electra Professional. If your main control box (called a KSU - Key Service Unit) is a plastic cabinet, you have the Level 1 system. If your KSU is metal, you have the Level II (2) system.
Dec 27, 2008 | NEC Electra Professional ETW-16DC-2
Comdial 3x8
I don''t think so. The 6600 and 67xx series were designed for the "N" Ksu's and work on the 1432 and higher systems. You're probably looking for 64xx and 35xx phones.
Oct 11, 2008 | Comdial (G1632) Modem
Maxtor Ultra ATA/133 PCI Adapter Card (999812) IDE Controller Logo
63 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
