I have a Otek PS 979 scanner but the slide are transparent as
5 Suggested Answers
  • 1335 Answers
SOURCE: Lide 600 film scanner. How does one secure the
The scanner comes with a film adapter unit that holds the 35mm film strip. It compensates for the fhinness of the film strip.
You'll have to contact Canon support if you need to purchase one or make a mask using thick paper or a tranparency sheet and attach your film strip with drafting tape (it does not stick aggressively and removes easily.
You might also check with a local scanner repair shop for a used adapter.
Wish the solution was easier.
Posted on Apr 27, 2009
mahhek
  • 657 Answers
SOURCE: scanning slides
Any adapter with the similar output and input capability should work
Posted on Oct 05, 2009
Alamo308
SOURCE: How to scan slides with Visioneer 9520 USB Scanner - it scans who
I have successfully used my Visioneer 9520 to scan 35mm slides, and they came out perfect. To do this, in my image editing software, I select File/Import/Acquire/Visioneer ScanManger Pro. This opens the VIsioneer scan manager window, where I select "Scan 35mm using:" and then I choose the desired scanning configuration, e.g., "35mm Better, 35mm Best, Custom" etc. See image below.
BTW: After several moves, I have lost my 35mm scanning template. Do you know where I can get another one, or do you know someone who could actually scan theirs and email the image to me? I could then create a duplicate from heavy black construction paper or card stock.
Posted on Nov 29, 2010
Keynan
  • 977 Answers
SOURCE: I have installed Arcsoft MedialImpression
Hi!
It would've helped if you specified the operating system you're using... There have been reports of problems initiating the program on Windows 7, especially of 64-bits.
Anyways, I'll advise you first trying run the program in a compatibility mode (link for Windows 7/Vista; works similar on Windows XP).
If this fails:
1. Uninstall the software.
2. Restart the computer.
3*. Clear remaining files/directory related to ArcSoft and/or Medial Impression in Common Files (within Program Files) and in Application Data (in your user directory -- in Local Settings and in Application Data itself).
4*. Clear the temporary files directory (link works for all Windows versions).
5. Reinstall the software...
The directories involve are usually hidden... To unhide them, follow this.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Posted on Feb 21, 2011
How do I scan transparancies? With the holder in place on the flat bed the whole frame scans and not the slide.
You need to put a piece of white paper, the same size as your slide on the back of your slide. Your scanner doesn't recognize the edges of the transparancy (it is looking through it), so if you place a white paper on top of your transparancy it wil recognize the edges.
Nov 15, 2011 | Epson Stylus RX500 All-In-One InkJet...
I cannot make the scanner recognise film instead of photo. The option is greyed out and I cannot select it for full auto mode - or any other mode for that matter.
Your scanner is not capable of scanning transparencies, You will either need a special slide/transparency scanner, or find out if there is an add-on attachment for yours
Jan 28, 2011 | Office Equipment & Supplies
Transparency adaptor won't close
Remove the transparency adaptor from the scanner bed (unscrew the two smaller screws, then slide back and off) and then remove the glass (and plastic frame) of the transparency adapter (there are six screws).
By the hinge there is a small white plastic switch. Usually the transparency adaptor hits this when it's closed, letting your computer know that it is ready to scan. What I did, as bcvideo did, was take duct tape and firmly taped the switch to the side of the transparency adaptor, using several small strips of tape.
The scanner works well now. You may need/want to put something on top of the scanner if it does not fully close.
Apr 08, 2008 | Epson Expression 1680 Professional Flatbed...
Scanning neg
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Jan 22, 2008 | Epson Perfection 3200 Photo Flatbed...
Epson 3490 does not find the slide I put in the correctly positioned provided frame
Dec 28, 2007 | Epson Perfection 3490 PHOTO Flatbed...
Scanner incorrectly reads frame position on film
Yes there is
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Scanner wont scan transparencies properly
I have the same problem with my 4990. This began when I moved to a new computer running Vista. I've updated all drivers to the latest version including Epson Scan for Vista but the only thing the 4990 "sees" is reflective documents. Negatives are not recognized at all. I know this is probably a different problem from what you are having but the effect is the same.
Apr 27, 2007 | Epson Perfection 4990 Flatbed Scanner
35mm Color Slides
Here they are for Mac and PC
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
Mar 15, 2007 | Epson Perfection 3170 Flatbed Scanner
Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Feb 04, 2007 | Epson Perfection 1250 Photo Flatbed...
Trouble scanning slides
Just a thought, but the "T" in the model number is for transparancy. When I moved to XP, I had to download a new driver from online but I specified 620UT not just 620U under BenQ. This new interface worked a charm.
Aug 25, 2006 | AcerScan 620UT Flatbed Scanner
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
