Acer az3730 Hi Need help My acer Aspire AZ3730 gives me this error message, 'computer unable to complete windows installation, reinstall operting system'. I tried to restart n re install in safe mode also loops back to this error message. I lost my recovery disks, any advice? Thanks.
    Genius:
  • 1,250 Answers
Press f8 during the boot up process then select the last known good configuration
Posted on Feb 10, 2014
SOURCE: I was adjusting picture on monitor and now picture completely messed up
  • Signal out of Range.
  • Out Of Scan Range
  • Horizontal frequency is out of range.
  • Cannot Display This Video Mode Out of Sync
This issue may occur if the signal from the video adapter exceeds the scan range of the monitor. The video adapter setting for updating the screen (the refresh rate) is incompatible with the monitor.
you should reinstall your video drivers in safe mode.
To restart in safe mode repeatedly press the F8 key during the computer startup. This will bring a menu where you'll be able to choose safe mode.
LCD monitor 60 - 75 Hz
Posted on Jan 25, 2008
SOURCE: Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Posted on Aug 20, 2008
  • 39 Answers
SOURCE: "Input Not Supported" after adjusting screen resolution
What resolution are you trying to run? The native resolution for your monitor is 1440 x 900, setting to that should fix your issue
Posted on Jul 13, 2009
SOURCE: The screen goes black ACER Aspire
I have the same problem with my Acer 5684 laptop. Just bought display backup light (CCFL) from ebay. Hopefuly will arrive within next 5-10 days. I will let you know if this solves it.
Posted on Nov 09, 2009
  • 107 Answers
SOURCE: I am getting a INPUT NOT SUPPORT message for my
The resolution selected in normal mode is not supported by your monitor.
Instead of booting into safe mode, boot into VGA mode - this should allow you to change the resolution - change it to one that works and then you should be able to use normal mode.
Hope this helps, Sherwin
Posted on Dec 21, 2009
How to fix error 17 by starting windows xp at acer aspire zg5
Error 17 sounds like a grub bootloader problem, IE: your Acer disk didn't perhaps reload the boot code for Windows, or remove grub entirely.
http://www.ubuntu.com/download
Ubuntu 10.10 Latest Version
which can repair what windows has ruined and is unable to fix fix the problem
either burn it to a disk as an iso and install
you might have burn it to an iso first then boot from the cd rom to install ubuntu or you might just try to install ubuntu directly from the download if it does not install you might save it to a folder then burn it as an isohttp://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
once Ubuntu has been installed on your computer has corrected the fault you will be able to reinstall windows
or keep ubuntu and install windows next door to it
you can have a dual boot computer with both windows and ubuntu linux you will need to partition your hard drive to do this
is a free partition program.
I have actually used this process to fix my computer with similiar problems and it works.
also
You might want to look at this
http://en.kioskea.net/forum/affich-4...aspire-one-zg5 also
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer pressENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Nov 27, 2013 | Computers & Internet
How do i reset my accer aspire 5336 laptop to factorydettings
This information can be found on the support page of Acer.com
http://acer.custhelp.com/app/answers/detail/a_id/2631
How do I reinstall the Operating System on my computer?
Select models, with Microsoft Windows, have the ability to have the Operating System reinstalled from a hidden partition built into the computer.
Note: During the process, all data stored on your computer will be overwritten. This means all your files, such as email and photos, will be erased. Therefore, we recommend making a backup of all personal data before starting the recovery process.
To start the system recovery:
  1. Restart the computer.
  2. When the Acer logo appears on the screen, press the Alt and F10 keys repeatedly.
  3. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
  4. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
If the ability to reinstall from the previous method is not available or fails, recovery of the Operating System will need to be from Recovery Media. If you do not have a set of Acer Recovery Media, you may purchase the set online from the Acer Recovery Media Order Form.
Note: If your computer does not have an internal optical disc drive, an external optical disc drive will be required in order to recover the Operating System using Acer Recovery Media.
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Thanks for using FixYa.com
Apr 28, 2011 | Acer Computers & Internet
Reset acer aspire laptop
hi there,
there are multiple ways you can re install windows in aspire one
1. within the windows logged in press alt+F10 and it will show you the software and select reinstall windows (factory default settings)
2. if you are unable to load windows start the computer and press alt+F10 and the recovery process will start automatically, and it will install windows and drivers for the notebook
Caution: It will erase all the data on the C Drive, Always take a backup of your data before continuing to installation
Regards, Bilal
Jan 12, 2011 | Acer Aspire One PC Notebook
Manual for Acer Intel Pentium E5700 Computer With 21.5" Monitor (AZ3730-E3222)
You can go to acer europe support site by the following URL.
http://support.acer-euro.com/drivers/downloads_gd.html
Then select Veriton X275 from the desktop category and choose the Document tab to download the user guide.
Oct 29, 2010 | Acer Computers & Internet
I have an Aspire 5050, I have bought a Kodak All in one printer. When I try to install it it gives me error code 1721. I was on the phone for 4 1/2 hours with Kodak and they advised that it is something...
Error 1721. There is a problem with this Windows Installer package. A program required for this install to complete could not be run. Contact your support or package vendor.
Sep 03, 2010 | Acer Aspire 5050-3242 Notebook
Reinstalling
Hard drive has bad sectors on it which is why its giving you that message even though you can go thru the restore. Normally going thru the system cd and then the recovery cd should bring you into windows with the device drivers installed.
Dec 10, 2009 | Acer Aspire 5520-5156 Laptop
My acer aspire4520 laptop is unable to detect my removable cd/dvd drive
You will need to install chipset driver but it will be much better if you reinstall all driver for it.
Acer Aspire 4520 driver for windows xp can be downloaded here :
http://www.drivercabinet.com/driver-acer-aspire-4520-windows-xp/
Nov 01, 2008 | Acer Aspire 4520-5582 Notebook
Acer 3680
Invalid / Non System Disk error In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined.
Complete listing of software applications
Help with software that begins with windows minesweeper, windows ... same time if they are causing issues with one another, or reinstalling the software.
Good Luck, Please dont for get to Vote/Thank You.
Dec 12, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
