Question about Honeywell HZ-709 Oil Filled Radiator Heater
Power doesnt stay on but a few seconds
It also shows the letter f before it shuts off
VPL-HS50 shuts down after few seconds
It must be a problem with electric connection. you should check whether it is OK or not. If it is okay, read instruction manual.
Jun 27, 2012 | Sony VPL-HS50 LCD Projector
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
I got a Compaq Presario SR1903wm .with red blinking light !!! power's up for about 20 seconds then shuts off !! doesnt even start up in Bios !! Dont know what to do !! should i replace the power supply...
check the ram memory ..if this shows up OK (verify it in another computer with the same specifications ) ...than the CPU is to blame ..open it up ..and remove for a few seconds the Bios battery to see if you messed up with the temperature settings ..This will reset to factory settings ..and if there is teh case with temperature limits too low set ..than it will power up after ..if it is the CPU you will have to change it
Jan 28, 2011 | Compaq Presario 5000 PC Desktop
My RCA Pearl turns on and then says " Usable memory exceeded, Please remove a few files" and then shuts down. I cant delete any files because my computer doesnt recognize the player. It will not stay...
paulmarie_co
You may need to check disk mangement to assign a drive letter to the player. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jun 30, 2010 | RCA TH1101 MP3 Player
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My iphone 2g only shows the apple for 10 seconds then shuts down
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
After this you'll need to jailbreak it too....
Sep 04, 2009 | Apple iPhone Smartphone
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Atwood water heater problems
probly the sensor on the modul. Take and clean it off with emery cloth and then reinstall it.
Jan 21, 2009 | RTO Atwood Water Heater - 6 Gal LP
Whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Won't stay turned on.
sounds like power fault but shouldnt be too expensive to repair,get local service center to check it out for you.,
May 13, 2007 | Akai LCT2701TD Television
Honeywell HZ-709 Oil Filled Radiator Heater Logo
56 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
