Question about Dryers
Dryer needs to go back together
Need to put back together my simpson dryer
5 Suggested Answers
gandhiforyou
  • 275 Answers
SOURCE: Simpson Maxidry 362. Tips on
Here are the steps to get the belt and tension pulley and spring attached properly.
1. Remove the drum from the dryer housing
2. Fit the belt around the drum, secure the belt to the drum (grooved side towards the drum, flat side away from the drum) with small strips of masking tape. Leave a loop of about 10-15 cm's free to fit around the motor. (This was Hurdle #1, it was next to impossible to hold the belt on with one hand and attempt to work out the tension pulley thing at the same time)
3. Place the drum back in to the dryer housing and rotate it so that your belt loop is facing the motor.
4. (Hurdle #2) Attach the tension pulley to the motor assembly bracket. (There should be slots in the bracket for the pulley bracket to insert into. The pulley faces away from the motor, about a 45 degree angle.
5. (Hurdle #3) Feed the belt through (under) the pulley and then over the motor's drive wheel or nub, whatever it's called.
6. (Finaly Hurdle) Attach the spring to the pulley assembly. In the centre of the dryer housing floor, there should be a seam, in the centre of this seam there is a small hole where the other end of the spring attaches too. Stretch and insert the other end of the spring into this hole.
7. Remove the masking tape that's holding the belt down.
8. Re-assemble dryer and your done.
Posted on Jun 20, 2008
vanni7
  • 163 Answers
SOURCE: dryer belt snaped
Hi!!! Make sure you install the belt correctly maybe this can help you..2447c24.gif
Posted on Jan 04, 2009
erpaalai
  • 999 Answers
SOURCE: dryer takes three cycles to dry took apart need help put back together
Model #?
If this is a standard dryer with the idler pulley, place the pulley into the slots to the left of the motor pulley. Bring the belt through the idler so it is running on the flat side of the belt and place the belt around the motor. The idler should be placing down pressure on the belt keeping it tight. make sure there are no twists all the way around the drum or it will pop off.
Eric
Posted on Jun 08, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I need to replace the
Hi lisavawter...
Your best bet is to buy a service manual, so it will tell you everything you need to know about servicing your dryer...
You can get one at this webpage...
Please take time to rate me
http://www.samsungpart.com/Products/Parts_and_Accessories/DV209AEW/XAA/Default.aspx
Posted on Aug 12, 2011
Belt come off! Need access
depending on the way the dryer is built you may need to take the dyer's top panel off then the front panel of the dryer to get to the internals while laying the dryer on its back to make it more easy to put the dryer back together when done if the belt however has snapped you can actually buy belts for the dryer you own er....one more thing make sure its unplugged before doing any of this but while its apart take your time to clean the dryer out with compressed air this will prolong the life of the dryer you own as well all dyers are easy to take apart and put back together as everything just snaps into place or screws back into place (PS: i worked on a LG TROMM dryer and it was easy as pie to put back together after cleaning and diagnosing it)
Feb 22, 2017 | Dryers
Simpson Maxidry 362. Tips on putting back together....? Roller tensioner spring attached to...?
Jun 20, 2008 | Dryers
I have a Simpson Ezy Loader. I need to replace the door hinge which I have purchased but I am unable to get the broken door hinge out of the door as the door wont come apart.
may i ask why are you replacing the hinge? the door is in two halves and held together by a few large screws, once you remove the screws you will need to put a flat blade screw driver in between the two halves of the door and pry it open, theres a heap of tiny clips that hold the two pieces together, it will be quite hard and may make a loud crack when you pop it open, dont worry you wont break anything.
Feb 04, 2017 | Simpson Washing Machines
Broken door on simpson maxidry 362
when it comes to whitegoods old is good. your dryer will outlast most new ones. buy the new parts it will b lot cheaper than a new dryer. not much goes wrong with the old simpsons. please reply if u need more help
Apr 11, 2010 | Dryers
I have a simpson eziloader dryer modal 39S500 the belt broke. i need a diagram on how to replace it. I also have to replace the bearing.
Hi I have a simpson eziloader 5kg Model: 39S500. I've just replaced the drum and put it all together but I have a spring that I'm not sure where abouts it goes can anyone help thank u
Mar 15, 2010 | Dryers
Which way does the belt go; on my simpson dryer. I want to re-attach it? oJc
remove the front and top cover lift drum upwards off drum glides put belt around drum set drum back down then over motor pulley and then onto idler pulley that should be all you need to do
Sep 13, 2009 | Dryers
Simpson Clothes Dryer wont start without assistance
your dryer has a start assist compressor go to this site to see it and that could very well be the problem. www.repairclinic.com/SSPartDetail.aspx?s=t-39p400-%3d%3db166i938994%PartID=938994
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
Simpson Clothes Dryer is smoking from the back
You should check your vent. is your vent in the front or back as some Simpson can vent in the front or back. You may be pluged with lint. safety therostat should shut down if too hot. but the lint may catch on fire. please check it before you use it again.. let me know what you find out? krazytech
Sep 10, 2007 | Dryers
Dryers Logo
13 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
