Question about MSI Computers & Internet
Where to get an MSI ub6250 driver for my MSI lap top?
SD Card reader no longer works after W8 instal. Device manager says that it needs the drivers.
Bubbabear64
  • 2794 Answers
SOURCE: SD Card Reader Not Working on Acer Aspire 5600 Laptop
Your card reader on your computer isn't capable of reading SDHC cards. You have to use a card reader approved for SDHC use.
Posted on Jul 15, 2008
i changed my hard drive .. and my computer has an SD slot .. but it wont read my card when i insert it .. odes it have to do with the new hard drive .. what can i do ..
Posted on Sep 10, 2008
SOURCE: MSI Wind Netbook sd card reader failure
For both an MSI Wind running Windows and Mac OSX 10.5.(4,5,6) do the following. Shut down the MSI Wind. Remove the power cord, any USB peripherals, and any SD cards in the slot. Remove the Battery Hold down the power key (with the battery removed for 2-5 seconds)  Release the Power Key Insert the Battery Insert the the Power Supply plug ((do not insert any USB or SD card yet)) Power on the Wind Now, insert the SD card-it should now show up on the desktop (in OSX). That should do it. Now insert any USB dongles/cables etc...
You have reset the PMU and bus start up. Any more Wind Questions?
Jay Rosen-WindManOSX
Posted on Jan 10, 2009
SOURCE: sd card reader not recognized when card inserted.
The solution is to go to your device in device manager on the driver tab simply disable then re enable the device - problem solved in seconds - no need to re install your OS system.....
Posted on Jan 18, 2009
benwabnick
  • 2404 Answers
SOURCE: Dell e1505 SD card reader issue
You installed the driver for your card reader for the laptop. If its not recognizing any cards you put in there then that means the reader is bad and since that is integrated onto the motherboard, replacing the motherboard would be the only option in order to fix that problem.
Posted on Jun 04, 2009
My PC won't recognize my SD cards
Just to be sure, it's an SD card (2GB or smaller) and not an SDHC card (4GB or larger)? If it's an SDHC card, is your card reader compatible with SDHC cards, or only with SD cards?
Mar 27, 2013 | Gateway Computers & Internet
Toshiba Satelite SD Card reader driver
It's a common problem when you do a OS upgrade, Is that the only device in Device Manager that isn't working? Any Unknown Devices? You didn't supply the Model of Toshiba, or the original OS? Download and save the Card Reader driver for Win 7, Change the Compatibility of the driver and install.
Feb 03, 2013 | Toshiba Satellite Computers & Internet
My sony vaio vgn nw26m sd card reader is not working when i insert a sd card it wont read it
Hi
this is what i would do to fix the problem there are several options and ways
start
type in device manager
when in device manager
have a look to see if you can see card reader in there
if not go up to the top row of writings and icons and hover your mouse over the 3/4 options on the right
one of them should say scan for new hardware
hit the scan tab
windows may or may not reconize the card at this stage but dont worry
if you can find it in device manager and it has a yellow warning sign on it
please double click it and go into the properties
then go into the driver
then try to update the driver from there
if it is in there please un install it
Now leaving the sd card in the usb
restart windows
maybe windows will then install/reinstall sd card driver
if not
please do all your windows up dates leaving the sd card in
if this does not work then please click on this link
www.sonyvail.com
go to support/downloads find your model and operating system
find the sd card driver
download it
install it
then restart laptop
hopefully all will be well
many thanks
Jun 23, 2011 | Sony VAIO VGN-NS135E/S Notebook PC
I cant open my sd/mmc card reader and writer.
Some SD and MMC have a security feature in them. If so you will need the disk that came along with it. After you install it then that's the time you can fully utilize your SD/MMC. SD means Secure Data / MMC means Multi Media Card.
If your card reader is not appearing in the My Computer then check if it is detected in the Windows device manager. Go to START > CONTROL PANEL > DEVICE MANAGER. Usually it is under the category of Disk Adapters or Human Interface Device. If it's not present then unplug and plug the device back in. Or try a different USB port to see if that will work. If it doesn't then most likely the reader is defective. But if it is detected and still not able to read the SD/MMC and the SD is being read by a different computer then the issue could be that the SD is not compatible with the reader.
Jun 08, 2011 | Computers & Internet
My problem is the driver for windows xp for microsd trascend UB6250
so far i know you dont need any driver to be installed when you connect your MicroSD to your PC, windows automatically installs the drivers for you try installing your card reader drivers and see what it does!!
I guess after reinstalling your card reader driver when you insert the card it should work..
If it helped you please say thanks and like/rate the comment please
Jun 06, 2011 | Computers & Internet
Card reader in toshiba lap top keeps reading that there is a XD pic card inserted when there is nothing in it at all ,how can i restore it/ reset to read my SD card
you should go to " device manager " & uninstall the sd card reader , then download the newest driver from here
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/download.jsp?ct=DL&soid=2585726&ref=EV
no just install the driver when it's finished downloading & this should solve your issue .
Apr 16, 2011 | Computers & Internet
Compaq Presario CQ50 SD card reader not working
go to this website and you will find the driver for that model
Jan 05, 2010 | HP Compaq Presario CQ50-110US Laptop
Card reader on MSI A6000 doesn't reconize card
Try different cards in the slot, if none of the cards are being recognized then go into the device manager and make sure the card slot drivers are intstalled, if you see something that says pci base device then that means the drivers are not installed.
In that case you need to install the drivers for it. If after you install the drivers the slot still doesn't work then that means the slot is bad and since its built onto the motherboard the motherboard needs to be replaced.
Dec 17, 2009 | ASUS Computers & Internet
Digital concepts high speed storage 2-n-1 card reader can't be detected on lap top
If your sister is using a windows based operating system like 95 or 2000, you will need to install the driver for that. The OS cant read anyting until you install the driver for it. But Windows Xp does not need any driver installation. Because it all ready has bulit in. If you are using Windows Xp then the problem can be harder to find out.
If u are using Windows XP, try to install the driver just in case,
then see if it works, if not then there can be a problem with the card reader. Try using this with other friends of yours. And see if the Chip is fine or not damaged.
Mar 03, 2008 | Electronics - Others
Sd card reader
Have you tried downloading the drivers for your SD card reader? You can obtain them for your laptop from the Toshiba download site here. Once you install the updated drivers, it will probably solve your problem. If not, leave a comment and I will try to help further.
Jan 15, 2008 | Toshiba Satellite A25-S307 Notebook
Computers & Internet Logo
53 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
