Question about Nixon The Rubber Re-Run - One Size - Drab
Nixon the re-run resets by itself - Nixon The Rubber Re-Run - One Size - Drab
How to reset time on nixon minimize 42-20 watch
Try Googling (Nixon)(42-20)(manual) without parens to get instructions.
Nov 17, 2016 | Nixon Watches
My Nixon Rubber Re-run watch's light button does not work, but instead, resets the entire watch. Would anyone be able to help me with this?
Probably dirt and/or dirty contacts. If you can open the watch up, try cleaning with an electrical cleaner solvent. (First make sure you can do it without running fluid into the front face of the watch. Perhaps holding the watch face up and spray upwards from beneath it).
Jan 01, 2015 | Nixon RUBBER RE-RUN A169 White/Black
I have a Nixon Lodown and I can't seem to figure out how to save a new tide location. it lets me select a location and then it asks me for the date. After i enter the date it goes back to selecting the...
Has it had a new battery recently? Some of these watches need to be reset properly in order for them to work right, if it has had a new battery this could be your problem. It would need to be reset from inside the watch
Dec 01, 2013 | Nixon Lodown Tide watch
Nixon rotolog light doesn't work
looking for the owners manual to the casio edific EFR-513sp watch
Jul 21, 2013 | Nixon Watches
Full Reset
I have a PDF for the entire manual. http://www.nixon.com/manuals/nixon_5130_4220.pdf Have fun. And take your time. The instructions are a bit specific.
May 11, 2013 | Nixon 42-20 Watch for Men
My nixon lowdown watch screen says ROM FAIL and i have only had it for 3 days how do i fix it ?
Hi You don't fix it. Hopefully you mean it's only 3 days old from being new and you can take back to the shop for refund/replacement.
ROM - stands for Read Only Memory and is basically the chip that all the software and information is stored on. This runs the watch and it's this that has failed. You could try reseting the watch by removing the battery and then replacing it.
Jun 09, 2011 | Nixon Lodown Tide watch
How do i fix my nixon tide watch whEn it says rom fail
Reset your watch with the help of users guide.
May 18, 2011 | Nixon Lodown Tide watch
With "The Producer" Nixon watch, can you reset the main stopwatch hand to zero? It resets to +4 second position.
Pull out the crown to the first or second set position then press and hold down the start button. The sweep arm should begin to move into the right position. Once it is at 12:00 or 0 release the button and press the crown back in.
Sep 12, 2009 | Nixon Producer NIX0022 Wrist Watch
Nixon The Rubber Re-Run - One Size - Drab Logo
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
rhodesworks
Are you a Nixon Watch Expert? Answer questions, earn points and help others
