What is the factory set password on the RCT-650VAS UPS
    Problem Solver:
  • 21 Answers
Try using "admin"
Posted on Feb 13, 2014
My kid forgot the password to her ZTE optic tablet, any ways around this so I can reset the password
You can reset the device back to factory setting by holding the power button for 15-30 seconds. CAUTION it will clear away your address book and any custom set ups you have done.
You also might contact your cell phone provider
Oct 13, 2014 | VanGoddy ZTE Optik from Sprint Tablet...
My daughter forgot the password to her ZTE optiks there a way to bypass this so I canreset the password
What is the password for a powerware?
You will have to consult the user manual for the default password. Usually default passwords are admin/admin.
Oct 16, 2013 | Powerware 9390 UPS System
Not charging
https://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&ved=0CFoQFjAE&url=http%3A%2F%2Fwww.heime.org%2FLists%2FPosts%2FPost.aspx%3FID%3D17&ei=ELBHUq2yKsXtrAe-8oCgAg&usg=AFQjCNFbohjnCV3CqMBkTlpcZ0VsJgn-jg&bvm=bv.53217764,d.bmk
Sep 23, 2013 | Computers & Internet
Powering down
your not very clear but here is what I'm assuming your saying.
Pins 5 & 6 - Any-Mode Shutdown
1. Pin 6 of the 9-pin communication connector is used for "Any-Mode Shutdown"
of the UPS output. This control input may be used in special applications
to disable the UPS output power-both Inverter and Bypass.
2. The Options tab allows the behavior of the Any-Mode Shutdown feature to
be modified. When the program opens, or the REFRESH button is pressed,
the UPS setting is read by the configuration program and displayed.
Auto-Enable Output
Pin 6 Logic
If version 1.6 (or later) is used with an earlier Liebert GXT2U model (with an
earlier UPS firmware version), the Any-Mode Shutdown features cannot be
changed.
If the configuration program is used with an earlier UPS model (with an
earlier UPS firmware version) that does not support the modification of these
settings, the Options tab will display a reminder of the factory default
settings. These cannot be changed.
! WARNING
Note that when this option is selected and the UPS output is
disabled using Pin 6, the UPS output can turn on automatically
and without warning if the Pin 6 connection is changed.
! WARNING
DO NOT CHANGE THIS OPTION from the factory default
setting unless you are ready to install a normally-closed
connection between Pins 5 & 6. This connection must be
maintained to use the UPS or to use the configuration program
again, including the ability to change the UPS setting back to the
default setting using the configuration
Sep 05, 2011 | Liebert GXT2-10000R230 (GXT2-10000R230)...
We re having problem with the 9120 powerwere UPS...no backup when the utility (commercial power ) is not available...the UPS shut down, and all LEDs went off.
open the ups and check whether the battery faulty or not if faulty replace it, if ok then check mosfet or IGBT used in inverter section if faulty replace it problem wil be solved
Mar 09, 2010 | Eaton Powerware® 9120 UPS System
Way to reset the user name/password
only thing i ran into was this: try it.
Default Password for APC Smart UPS
Description
Manufacturer APC Protocol Multi Access Admin Model Smart UPS User ID apc Password apc
Feb 19, 2010 | Enterasys APC Smart-UPS 2200 XL...
Dear Sir i will like to ask you if it is possible to change or reset the actually password-protector that have an UPS APC Silcon SL60KF with a master password or reset and for this the ups recover the...
I have had the problem of APC's PowerChute software forgetting my password. No joke. I write these things down when I set them.
Two options:
Call APC support. They are awesome. Smart, well spoken and free. You will need the model number and serial number from your UPS. (800) 555-2725
Remove and reinstall the APC software. During the reinstallation you should be prompted to set a new password.
Vote for this solution if it helps.
Aug 17, 2009 | APC Computers & Internet
The UPS dont go to on batteri
Replace the batteries with new one then power the UPS without load for three hours or more so that the batteries can be charged. Then disconnect or switch off power to the UPS and observe if it will till be on using the batteries. If it will be ON then your problem is solved but if it goes off then your UPS is on BYPASS
Apr 09, 2009 | Powerware 9120 UPS System
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
