Question about Sylvania Televison & Video
Where may I find a LCD inverter for Sylvania SK2201W-B?
The unit powers up with an amber blinking light.....no video display.
SOURCE: Sceptre X30SV LCD display goes black with sound... Inverter? and other parts...
I too have the same problem...Searched and waited long time for parts. I have replaced everything and the thing still flashes and goes blank but has sound. Not worth anymore stress. My neighbor is an electrical engineer who I used to think can fix anything. He too is baffled. My fix suggestion... Getting a new LCD (not a Sceptre) tonight...with an extended warranty...Sceptre (and their tech's) no help if you don't have a warranty. I learned my lesson!
Posted on Jul 09, 2008
CAYPIANAN
  • 227 Answers
SOURCE: Samsung LCD TV LT-P2045U power issues
yes my friend check the capacitors in the power supply. some techs call them pregnant capacitors
open the set carefully and check the power supply.always remember to unplug the set before you do anything.
Posted on May 12, 2009
roety
  • 585 Answers
SOURCE: power light blinks amber/yellow
Hi my name is Roety,
I can help you with your issue ,
IF you see no light on the screen at all no menu . message at all.
The invertor or screen may be at fault.
The only easy repair short of replacing a board is checking/replacing swollen capacitors on the power board
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Dec 22, 2009
  • 1684 Answers
SOURCE: I have the same power supply problem on my
You may be able to repair the board instead of buying a replacement board. If you are up to a little soldering it may save you a good bit of money for the repair. If you are interested just take a few pictures of the boards and email them to us at tech@ccl-la.com We will check them out and give you some pointers on what to do. Most power supply issues with the blinking power lights are caused by blow capacitors on the power board. These are fairly easy to replace and the replacements are less than $20 usually. To get an idea what capacitors are and what will need to be do to repair you unit check out our pages at :http://www.ccl-la.com/blog/index.php/capacitors/ You may want to look over the repair guides for other units we have posted too. If you need parts we can also supply them for you. If you have any additional questions just contact us at: tech@ccl-la.com
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 19, 2010
budmrtn
  • 11361 Answers
SOURCE: power light just blink on my sylvania lc320ss9a lcd
It can be the power supply is unstable due to bad DC filter caps, or it is sensing short circuits caused by backlight board, you will have to take it apart and start by visual inspection first, look for bad caps iwth leaking/bulging tops (caps can look OK but can have high ESR). Then you need to do voltages checking.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 14, 2010
I recently got a used Sylvania 22" TFT-LCD
you posted sylvania to HP , whY?
The did not post a question, is this show and tell.
or the CELL phone battery died.? LOL
Aug 10, 2017 | HP 22" Widescreen Flat Panel TFT LCD HD...
Acer V173 with flashing amber led. No picture. cable good. other monitors work at this connection.
I have this same problem. Blinking amber Light and no display. on close examination I am seeing the video image attempt to come up, but with no back lighting. I think there is a power supply problem. I will post again if I learn more.
Feb 24, 2011 | Acer V173 b Monitor
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Display skcrin black but LED not blinking
First, connect this monitor to another computer, if you still do not get a Windows image on the Samsung LCD monitor then it is faulty. The fault could be a faulty inverter board that supplies high voltage to the CCFL lamp or the fault could be a faulty CCFL lamp.
Parts for this monitor could be avaiable from LCD Parts, theie WEB site is :-
www.lcdparts.net
Jun 23, 2010 | Samsung SyncMaster 510N (Silver) 15 inch...
The on/off of pc monitor (LCD) is blinking.
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Apr 14, 2010 | Envision 19" Widescreen Flat Panel LCD...
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
Power almp blinks
i have this problems before its an inverter problem. pls. repair the inverter.
Jun 28, 2009 | Dell E173FP 17" LCD Monitor
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Dell 1701FP monitor - power buttons blinking - no display - no white screen
hi my name is joel joely from etech vanuatu limited. my dell LCD monitor is just blinking power light on with orange light and also power switch not working if turn it on or off no display on screen.
my email address is joel@etech.com.vu
thanks
joel
Sep 06, 2007 | Dell UltraSharp 1701FP 17" LCD Monitor
Televison & Video Logo
24 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
