Question about Sharp Notevision PG-B10S Multimedia Projector
Lamp light solid green - Sharp Notevision PG-B10S Multimedia Projector
Tv light blinks green then solid then red
Hello:
From the sound of your description of your problem you likely have a defective lamp. Feel free to give us a call at 866-764-5822 and we would be happy to help you troubleshoot the problem over the telephone.
Best Regards
Dan
DLP Lamps Projector Lamps Specialty Lighting
Mar 31, 2014 | Mitsubishi WD Televison & Video
Solid green light but no picture
I think this is a projection set. Sonys are called SXRD type lcd projection . Little diff from DLP types. But they do have a lamp. Unplug set plug back in then turn on . Count blink code. Check lamp also. blink code is 2 digit code. Code will give clue to failure.
Oct 01, 2013 | Sony KDF-E42A10 42 in. LCD Television
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Infocus X3, no light, LED is solid green.
the colorwheel. if it does not spin, the lamp will not light.
Aug 26, 2009 | InFocus Proxima UltraLight X350 Multimedia...
Intermittent lamp turn off
I was told by the repair service to unplug the power cord for about 5min. This resets the internal computer. I think this helps but does not cure the cause. Good luck.
May 22, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
SONY GRAND WEGA
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
May 20, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sharp Notevision PG-B10S Multimedia Projector Logo
19 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
