Question about Cuisinart DGB-650 Grind & Brew 10-Cup Thermal
Dgb-650 how to fix on and off light
Why does it shut off with 2 cups of water left in reservoir?
sounds like you have a defective water sensor, needs to be replace or taken to be fixed
Dec 01, 2015 | Cuisinart Dgb-650 Series 10 Cups Coffee...
Just bought a cuisinart grind & brew dgb-550 and can't get the program setting to work. Tried putting in a time and leaving it and tried pushing the program button after entering the time.
Push the program button one more time - the first push allows you to set the time, the second push stores the time you have just entered, and then you have to press it one more time to make the light next to the program button light up tell it to brew at the set time.
Aug 23, 2009 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
DGB-600BC - Coffee maker (grinder combo)
Unplug for 20 minutes or longer - this one has a longer than normal reset.
Dec 07, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Power surge fried our unit
Contact cuisinart and see if the will replace it under warrenty. This happened to mine, but they would not replace mine because it was a refurbished model. I am going to rip mine apart to see if I can fix it this weekend.
Jun 18, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart DGB-300 buttons not working
Don't take it apart - just unplug it for longer than 20 minutes - it should cause the self-clean light to shut off.
Apr 13, 2008 | Cuisinart DGB-300 Coffee Maker
DGB-600BC
I have had the Cuisinart DGB-600BC for a bit over a year. The coffee grinds, and then sometime during the brewing cycle, it will go, "beep beep, beep beep, beep beep..." on and on.
I think I have traced the problem to the latch on the top lid that you open to access the bean hopper. I believe the latch sticks and doesn't close the lid tightly enough. It will appear to be closed, but the latch isn't all the way in place.
So, there is a small screw on the inside of the latch in the lid. Carefully unscrew this, remove the screw, latch, and the small spring. Remember which way the latch faces.
With a warm damp paper towel, clean the latch and the slot in the lid that the latch goes into. Reassemble, and make sure the screw is not so tight that the latch doesn't move freely.
This should solve your problem.
Jan 21, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Cuisinart DGB-650 Grind & Brew 10-Cup Thermal Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
