Question about Mitsubishi WT-42311 42" Rear Projection Television
Mitsubishi wt-42311 x-box 360 hdmi-dvi for 1080i
I recently inherited a Mitsubishi WT-42311 and want to hook my x-box 360 up to it. Currently, I am running the 360 by HDMI to a Rocketfish HDMI-DVI adapter and into the TV from there. However, this is only giving me 480/480i instead of 1080i. Is there anything I can do to correct this?
  • Anthony McGregor
    Anthony McGregor Feb 10, 2014
    Got it. I thought my 360 was already set to 1080i. It wasn't.
5 Suggested Answers
style_points
  • 34 Answers
SOURCE: Mitsubishi WT-42311 DLP Bulb Replacement
Your access should be a a panel near the back or side. You will see that it is somewhat easily removed and should have maybe one or two screws. You will see the casing to the lamp. Go ahead and remove it. Now unscrew the old bulb and replace it with a new one. There is not a lot of screws holding it together. It's a fairly easy process once you find the lamp. You should see the lamp once the panel is removed.
Posted on Apr 27, 2009
ladywinn
  • 5138 Answers
SOURCE: i have a mitsubishi 1080 series wt-42311
STKs,one of them controls startup if bad TV will not come on.STKs are big black ICs will have part# on them. call Mats for parts you have 2 replace both. 1-800-628-1118
Posted on Sep 18, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi tv model wt-42311, error code 2-2. what can i do?
2,2 IS short protection and 95% chance it means one of the two pico fuses that protect the convergence IC chips are bad.
This model uses two of the chips: STK-392-110 and you would have to pull the light box out to replace them safely (total parts cost will be under 30 dollars).
It involves getting at the chips and the fuses and replacing them: how much skill do you have?
SD TECH
Posted on Mar 25, 2010
SOURCE: I have a 2002 Mitsubishi
I have a 2005 rear projection mitsubishi medallion hd tv.... for some reason the hd channels do not look as HD as they used to... I went to my cable company and got a new cable box... but it is still not a crisp as it used to be. Could it be the settings on the cable box, settings on the tv or could something have gone bad in the tv?
Posted on Aug 27, 2011
How to connect hdmi from the cabel box to the tv
First things first. Does your cable box have a HDMI output on the rear? If so, mearly aquire a HDMI cable from one of your TV electronics retailers and connect it to one of the unused HDMI inputs on your HDTV. Use your TV remote to switch to that HDMI port and POOF.. there you go.
Jan 15, 2012 | Mitsubishi WT-42311 42" Rear Projection...
It does not have a HDMI cable connector that my cable box requires. What can I do??
Connect it using the composite and audio RCA connectors(the round red, white and yellow ones) that both your tv and the cable box have.
Aug 20, 2010 | Mitsubishi WT-42311 42" Rear Projection...
How do I change it from 480 to a higher resolution?
on your cable/sat or video game box
find the output video settings and bump them up to 720p or 1080i
you need to be hooked up with an HD cable like component video, or HDMI
Jun 15, 2010 | Mitsubishi WT-42311 42" Rear Projection...
SD TECH
Mar 25, 2010 | Mitsubishi WT-42311 42" Rear Projection...
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 Has sound, no pic. Hear the relay click but no power going to the projectors.
Sounds like power supply problem. Possible high voltage problem not allowing basic saftey circuit to be normaled. Professional repair suggested.
Jun 27, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Jan 14, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi wt-42311 convergence issues
Replace convergence IC's. There are two IC's that start with STK.
Jul 12, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WT-42311 hd tv has "pulsating" problem
A Mits qualified tech and/or warranty repair facility near you should be consulted.Involve Mits in the repair loop for accurate info.
Sep 26, 2007 | Mitsubishi WT-42311 42" Rear Projection...
Open Questions:
See all Mitsubishi WT-42311 42" Rear Projection Television Questions
Mitsubishi WT-42311 42" Rear Projection Television Logo
19 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
