Question about Maytag M7DH45B2A Dehumidifier
Maytag Connector Hose 5214A20027A - Maytag M7DH45B2A Dehumidifier
I do not have the adaptor for my maytag dehumidifier model #M7DH45B2A to attach the garden hose for continuous drainage. Where can I get one, or could you give me the specifications so I can go to the...
The drain hose connecter, which accepts a garden hose type coupling is an intricate part of the unit. It is not removable. If yours broke OFF, that's a different story. However, that Part # 5214A20027A Drain Hose Connect is no longer available. As are many other parts for Maytag Dehumidifiers, that were manufactured by the now defunct, Fedders.
Unfortunately, I do think you'll be able to run out to the local hardware store and get parts to fabricate one. As the lion's share of the part is internal. http://www.appliancefactoryparts.com/search/partinfo.php?partsID=282294&modelsID=116727&typeName=dehumidifier
I'm sorry I don't better news for you. Thanks for choosing FixYa.
Jul 26, 2011 | Maytag M7DH45B2A Dehumidifier
How do i make it continue to run with no bucket so it does not fill and and so i don't have to empty it
Attach a length of garden hose no longer than 5 feet, to the threaded drain hose connection that was supplied with your unit, to carry water to the drain.
1. Remove the drain-hole cover on the back left side of your unit.
2. Connect a garden hose to the threaded drain hose connector.
3. Push hose connector tightly to the drain-hole on Rear Grille with the arrow on the tab pointing UP.
The hose attachment will accept a standard garden hose fitting.
Do not over tighten the hose when connecting it to the hose connector,
use a rubber washer and tighten by hand firmly without stripping the
plastic threads.
When being attached to hose connector drain hose connection,
do not bend or kink the hose. The hose should lie flat from the
dehumidifier to the drain.
Jul 04, 2011 | LG LHD45EL Dehumidifier
Can I connect a hose so the dehumidifier can drain itself
if it has a place to connect a drain hose to there usually inside the pan the connector should have came in the box with the DIRECTIONSSSSSSSSSSSSSSSS
Jun 27, 2011 | Maytag M3DH30B2A Dehumidifier
Sears part 5214A20027A
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Jun 22, 2011 | Kenmore 54501 Dehumidifier
I attached a hose to the drain hose connector. When I insert it into the drain hole it is blocked by the back of the dehumidifier. What iw the correct way to insert? Can you send a better diagram?
The drain hose connector MUST be attached to the unit, before attaching the garden hose.
First, the connector is attached to the unit. Second, the hose is hand tightened to the connector.
If you haven't been doing it in this order, that's the problem.
Mar 13, 2011 | LG LHD459EL Dehumidifier
There was a hose connected somewhere on the bottom of our Maytag dehumidifier. It was leaking and I pulled it out. Now the indicator light is on and it beeps showing the bucket is full. How can I get it to...
Most likely the drain tube usually a garden hose connector on the condensation tank. My guess is the drain tube has broken free of the holding tank mabe from someone accedently pulling on it? That would explain the "bucket full message"
Take a real good look at the bucket at the rear of the unit see if something there is broken off. You can also look at the end of the hose to see if there is something in there, /my guess is that u need a new condensation collection bucket that will have the connection on it for the hose.
Also please check http://www.applianceaid.com/news.html#recall noticed a possable recall for matag
dehumidifiers
Mar 10, 2011 | Maytag Dehumidifiers
I purchased a LG Dehumidifier MODEL LHD45EL and I followed instructions to attach a hose to it for the drain. I removed the drain hole cover and I don't see a drain hole connector or a hole to install it...
Remove the drain bucket. on the top there are two pieces that can be removed just by taking them out. they are just laying in there. 1 is the brush the other is the "drain tube insert" it is a plastic tube and has a threaded fitting on one end. take your garden hose with a female connector on one end just like you were going to install on your spicket outside of your house and connect it to the threaded end of the "drain tube insert" make sure you knockout the round plastic drain plug cover hole located in the back of the unit (it is behind where your power cord was stored) it has three tabs to break. remove drain bucket. take the drain tube with hose attatched and insert it into the drain plug hole in the back and attach it onto the drain outlet (the drain outlet is inside the drain bucket side at the top it looks like an elbow fitting) push the tube so that the flap with the arrow is flush with the back. once you get the "drain tube insert" almost all the way flush with the back -->if you look inside the drain bucket side you will see where it fits over the drain outlet
Jul 22, 2008 | Maytag M7DH45B2A Dehumidifier
Missing hose adapter
It might be a problem since these units were made by Fedders for Maytag which is now owned by Whirlpool :inhale: but I found part number FD9520-010 "drain hose". If not, a length of dishwasher drain hose with a male garden hose fitting on one end would work fine
Aug 15, 2007 | Maytag M7DH45B2A Dehumidifier
Dehumidifier Kenmore 580.54501
hose connector is Sears part # 5214A20027A
dehumidifer is Model # 58054501300 or 58054501400
use these numbers on searspartsdirect.com
Jun 11, 2007 | Kenmore 54501 Dehumidifier
Maytag M7DH45B2A Dehumidifier Logo
232 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
