Require xtal for toshiba remote control ct90253
Need code to program a toshiba tv
Entering the Remote Model No. (May need to enter it as 3020) and Make & Model in the link below should give you the required code.
http://www.oneforall.com/en_UK/support
May 12, 2011 | One For All URC-3021 Remote Control
Toshiba VC-L2B Remote Control Sound volume bar is moving up and down, but there is no sound out of speaker.
Check to make sure the wiring between the sound bar and your audio source is hooked up correctly. Check the source to see if it has it's own volume control. Many TVs require external speakers to be enabled in the "audio" section of your TV's "Settings" menu.
May 04, 2011 | Toshiba VC-L2B Remote Control
TOSHIBA SER0324 Remote Control. I just got a Toshiba TV with this remote and I am unsure how to set it up.
Hello
You can prgramme with
toshiba remote control with Toshiba TV, eventhough you haven't its manual or codes. Proceedings are :
1. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
Mar 12, 2011 | Toshiba Televison & Video
I have an Toshiba VT-752EW video recorder and when I reset the time, the time stays the same time and dosn't move on.
I would check/replace the clock Xtal. If you are not using off air programmes anymore the clock will not auto update.
Feb 28, 2011 | Televison & Video
My led is blinking...and the remote isnt working....i have changed the batteries but still the problem remains...
Possibel shifting of the frequency of the remote. You can remove the remote and check for fault in the Xtal . Solder the section including the remote controller IC. This can be also defective. If the fault is still repeating a further confirmation must be done on the system receiver before we can confirm to change the IC or the Xtal. Get help from a similar model to cconfirm if you can or else you must take the challenge of changing the IC. Try using a universal remote if it works. Hope you get this right . Good day
Aug 11, 2010 | Altec Lansing VS3251 Speaker
Remote stopped working
open your remote and look if you dont have a bad soldering some where use a good magnifier
if all look good its could be the ir led blow or the
xtal frequency controler.it as to be some ting like that
hope that will help ;sometime the batterry look full or test over 1.5 but theres not good replaced before to be shure..
have a nice day
May 13, 2010 | DISH Network 721 DVR Remote Control
I need the codes for a toshiba tv
I have code listings for different devices. The codes listed for a Toshiba TV are:
0036, 0060, 0149, 0154 and 0156. Start with 0156 first. It your device only requires three digits, drop the 0. Hope this helps.
Oct 25, 2009 | One For All URC4220 Remote Control
My remote control doesn't work for lg tv model # 37lc2d
have you tried and see if the led is flashing wile looking through a camera on a mobile phone ? this will tell if the remote is faulty.
if its not flashing then open up remote and look for bad joints/connections etc.
the most common is around the led sender and the xtal unit.
Sep 07, 2009 | LG 37LC2D Television
Remote control won't work. Have put in new batteries.
We have to CHK to see if the remote is functioning, Do u have a camera phone, if so look to see if the Infra red beam is flashing when you press the button, through the camera you should see a light if the remote is working. If not CHK infra red LED if read open change it. IF light flashes continuously change transistor. If the LED dont light but the LED is good CHK the XTAL.... Another way to check beam is a little transistor radio with the am band press remote while tuning until you hear a beeping sound. If the remote is working the sensor on the player itself is bad and need to be replace.......
Aug 10, 2008 | Toshiba Televison & Video
How to use Toshiba 32D46 32" TV with Comcast 3 in 1 Universal Remote Control
Most univ. remotes have a search mode if code entry won't work-
Do you have the comcast instructions ? Something like.....
1) Tv power on
2) Push set-up or program on remote
3)Touch tv button on remote
4) Point remote at TV and push power off. Repeat until TV turns off.............then
5)Push enter to save....
Hope I helped you........T.
Nov 07, 2007 | Toshiba 32D46 32" TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
