Question about LG HT905TAW Home Theatre System
LG HT905TAW won't mate with rear speakers.
I have had the system for about 4 years, since moving into our new house I haven't been able to get the main unit to mate with the back speakers. Have already tried to set a new wireless id as per owners manual and still no luck... HELP!
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
It could be there is another electrical device nearby interfering at a electromagnetic level.
Electromagnetic Interference/Compatibility
Nearly every electronic device is susceptible to electromagnetic interference (EMI). To avoid the possibility of electromagnetic interference and/or compatibility conflicts, turn off other components that might be interfering
Wireless phones are a common one
Good luck
Posted on Feb 10, 2014
4 Suggested Answers
SOURCE: LG wireless dvd reciever system
Hi, I had the same problem, it seems to be a design error of LG or a typical problem with some component in the wireless transmitter. It is basically caused by the transmitter heating up, leading to a clock drift with the result of the receiver losing the signal. I tried to cool the transmitter in the fridge before using so it will run for about half an hour before producing this error (depends on the room temperature as well). My solution is to remove the plastic case of the transmitter unit and place it in a cool place where it does not catch heat from other devices. Without the case it does not overheat and also takes less space, just be careful if you have children. I placed the naked Tx unit behind the TV so it does not matter. Hope this works for you as well.
Posted on Aug 31, 2009
hoty252000
SOURCE: i have a lhb975 5.1
I also have the lg lhb975 home theater i went through everything sugested by other people and web sites. i talked to an electronics expert that is a friend of mine, and we both went through all the steps again. just to make sure i did not miss any steps. the solution that we came up with is that the wireless card inside the main unit is defective, and that it should be sent back for repairs if under warrenty. if it is out of warrenty it should be taken to a repair shop. to have the card replaced and reset.
Posted on Mar 11, 2012
  • 174 Answers
SOURCE: how to re mate rear speakers on ht905taw
rear speakers side try a different brand with the same watt and frequency
Posted on Apr 17, 2012
I carn't mate my rear speakers with my audio system
press stop on the unit and mute on the remote at the same time
Jul 31, 2014 | LG LHB326 Home theater system with iPhone...
Speaker setup
just plug in a cable from the out put of your amp. direct to the speakers should work
Apr 17, 2012 | LG HT905TAW Home Theatre System
How to re mate rear speakers on ht905taw
Hi, I have Mazda 626 year 2000 and I won't to
Four (4) total. 2 (6 x 8 inch) in the rear and 2 (6 x 9 inch) in the rear deck.. See my site for more details
Mar 13, 2012 | Car Audio & Video
Wire color codes for '95 Ford stereo
i will post 96 Taurus. Not sure if the same as 95. you did not say which radio you have, base or premium.
please rate as fixya if this is what you need
Base Audio System With/Without Cassette Player
Pin Number Circuit Circuit Function 1 729 (R/W) Battery Feed 2 57 (BK) Power Ground 3 434 (LB/BK) Pulse Width Modulated Illumination Signal (Analog) from Headlamp Switch 4 1002 (BK/PK) IGN/RUN/ACC 5 640 (R/Y) IGN/RUN/START 6 694 (BK/LG) Logic Ground 7 — Not Used 8 — Not Used
Pin Number Circuit Circuit Function 1 593 (DB/W) Tape Audio RH + 2 594 (GY) Tape Audio RH - 3 57 (BK) Ground 4 833 (T) Audio Communications Protocol B 5 1068 (LG/BK) Audio system ON 6 723 (GY/R) Phone Wake Up 7 — Not Used 8 59 (DG/P) Rear Defrost 9 503 (BR/LG) Tape Audio LH + 10 504 (W/PK) Tape Audio LH - 11 — Not Used 12 832 (LB/PK) Audio Communications Protocol A 13 — Not Used 14 — Not Used 15 1010 (DB/O) Heated Back Window 16 — Not Used
Pin Number Circuit Circuit Function 1 803 (BK/PK) RH Rear Speaker (-) 2 802 (O/R) RH Rear Speaker (+) 3 811 (DG/O) RH Front Speaker (-) 4 805 (W/LG) RH Front Speaker (+) 5 801 (T/Y) LH Rear Speaker (-) 6 800 (GY/LB) LH Rear Speaker (+) 7 813 (LB/W) LH Front Speaker (-) 8 804 (O/LG) LH Front Speaker (+) 9 — Not Used 10 747 (R/PK) Power Antenna (Up Signal) 11 — Not Used 12 694 (BK/LG) Ground 13 694 (BK/LG) Ground 14 720 (R/Y) B+ Supply
Mar 06, 2009 | 1995 Ford Taurus
LG HT905TAW Home Theatre System Logo
206 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
