Question about Nikon Coolpix S4000 Digital Camera
Screen has a giant blue line through the center and can only barely see about 1/6 out of the screen
Still opens and works and takes pictures. Cannot see through the screen. There is almost no visibility. Is it internal? Something with the lens?
    Top Expert:
  • Nikon Master
  • 6,702 Answers
When you can make pictures, and view them on a computer and not on the camera screen, nothing is wrong with the lens or the photo sensor. But I think something is wrong with the LCD screen. Cold be the screen itself, but also the connection to the screen or deeper in the camera. If you can't solve a camera problem, after removing the battery, and reinserting it after a few seconds, the mostly you should contact the service centre. Be aware that some repairs can cost more than a new camera of the same quality. So ask what it will cost first.
Posted on Feb 10, 2014
4 Suggested Answers
  • 39 Answers
SOURCE: problem with lens
It is possible you have the display turned off... Some cameras allow you to do this to save battery.
Posted on May 02, 2008
SOURCE: Light rays and beams in pictures- help!
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
  • 571 Answers
SOURCE: my coolpics s6 has a black screen when in picture
Switch on the screen in setup. The screen is now in 'power saving' mode and does not lit up while taking pictures.
Posted on Nov 26, 2009
5-APCP-GFCI little giant pool cover pump works but shuts off after 10 minutes at first then less and less time after that until it barely stays on..Heat problem?
im betting this ones got a load of stuff in the suction screen and maybe inside housing as well , sure sounds as if pump is cutting off from thermal shut off too me
Oct 21, 2013 | Little Giant 5-APCP, 1/6 HP, 1200 GPH -...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Color lines out of focus
dc2eb76.jpg MikeNJ1964
Rank:guru_s.gif Guru sony.gifSony Expert
Rating: 89%, 674 votes
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Did you think this was helpful? Yes No
new MessageRate('spn1737581','spn1737581cnt','spn1737581stats','spnRateWord1737581','div1737581_yes','div1737581_no','imgStar1737581','ancChangeRating1737581','divChange1737581',1737581,0,0,0,false); Solution #2 posted on Jul 04, 2008 Asker's Rating 0%20stars_w.png
noavatar_s.gif gator149
Rank:nonexpert_s.gif Apprentice sony.gifSony Expert
Rating: 0%, 0 votes
MikeNJ1964 was exactly right! I have a Sony KP-65WV600 that had horizontal green lines that showed when the picture was darker. I had to remove 3 screws on the right and left side of the tv holding in the speakers...carefully pop out the middle panel from the clips holding it in....remove 4 screws from the cardboard in the middle and remove the cardboard. I then saw the six screws. The adjustment screws were the three below. I turned the middle screw until the lines dissapeared. I tried the left screw and blue lines appeared which I then adjusted away.
THANKS a bunch. SAVED me money!!!
May 15, 2009 | Sony KP-65WV600 65" Rear Projection...
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
Giant blue spot on 50" Hitachi LCD HDTV
The problem is an expensive one. The blue display has become distorted due to excessive heat overtime. The blue display is closest to the lamp and gets most of the heat. The Light Engine must be replaced by a repair shop to correct the problem.
Mar 22, 2009 | Hitachi 50V720 Television
Curved blue lines on screen.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence
Did you remove 1 leg of each resistor out of circuit when you checked the resistors? sounds like thier is still one resistor open or maybe one of the new IC pins need abit more solder.
Apr 09, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Dec 02, 2007 | Nikon COOLPIX L4 Digital Camera
No picture
a bright thin line in centre is called horizontal line. first of all do not keep tv on unless it is rectified. BUT If you want to put on tv keep brightness minimum to protect your screen for any demage. now solution your problem is in vertical section. 1 check vertical supply. 2 check parts in vertical section or loose contact. 3 yoke connrctor loose 4 ic defective It is not serious problem can be rectified easily
Sep 19, 2007 | Toshiba 32DF46 32" TV
Nikon Coolpix S4000 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
