Question about Grinders
Porter cable hello, i have a 8" porter cable variable speed w/light bench grinder.when i first turned it on it was making a humming noise after it reached and leveled out the speed , same thing as i increased the speed. even at its highest setting .two days later turned it on stated and suddenly stopped running .traced it to a small fuse in the control board cant tell what size it is.also i notice it had a 250 volt ac capacitor,but i is wired from the factory for 110/115 .i jumped the fuse out and it ran fine but still made the loud humming .p.s. it has little vibration .
    Genius:
  • 1,406 Answers
DO NOT leave it that way - that fuse is for YOUR protection, and the protection of your family and neighbors.
That humming is probably an byproduct of the speed control, not too much to worry about. The vibration should go away almost entirely when you reset the wheels to run true and dress them to balance.
The capacitor is your starting capacitor - its voltage rating is completely unimportant - that's a max voltage rating, and they only wanted to stock one capacitor, not have one for the 120V versions and a second one for the 240V versions.
Did you by chance start working on this grinder while it was still under warranty?
If the wheels turn freely when the power's off, and if the grinder doesn't get awfully warm when it's in use, then I'd think that the problem is within the speed control board.
Posted on Jul 29, 2014
SOURCE: grinder won't stay running
what is the mf(microfarad) rating and the voltage,then go to an industrial electical shopand buy one for the correct voltage and an (mf) equal or greater ,but not by more than 10%---mine cost $9.00-in Maine---good luck- MATT
Posted on Jan 04, 2009
  • 718 Answers
SOURCE: switch and capacitor crapped out on 1/2 hp Sears bench grinder
Replacement should be simple. Just do a one for one hookup with the new part, after you unplug it first.
For a diagram go to;
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=397.1949&productCategoryId=0721000&brandId=0247&modelName=CRAFTSMAN-1%2F2-H.P.-GRINDER&diagramPageId=00001&documentId=00023041&pop=flush
Posted on Mar 28, 2009
  • 52 Answers
SOURCE: I need an owners manual for delta gr450 8
Here's a link to download the pdf.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A15786.pdf
If it doesn't work, start here:
http://www.deltaportercable.com
Posted on Mar 02, 2010
  • 4088 Answers
SOURCE: My 6 inch Cummins bench grinder stopped working.
Try wrapping a thin cord around the shaft many times to allow the shaft to be spun in the normal running direction when pulled. Pull sharply on the cord and turn the motor on--if the starting capacitor is bad, the motor should continue to run until shut off. If there is no capacitor, then the motor uses a start winding and a centrifugal switch to start. The switch is supposed to open when the motor comes up to speed. If you used to hear a loud 'click' when the motor was shut off and slowing down, then you likely have the start winding and switch. If the contacts on the switch become burned and not make contact, then it will display the symptoms you mention. You will need to access one or the other end covers to reach the switch. Hope this helps!
Posted on Jan 10, 2011
  • 403 Answers
SOURCE: I have a single speed Delta 8" bench grinder. How
as for slowing it down, no problem. Hook it to a cord with a dimmer switch connected to it. Make sure your running with the same power rating though. As for a dripper, no ideas just yet.
Posted on Mar 10, 2011
Mar 10, 2011 | Delta ShopMaster 8in Grinder with Light...
No motor replacement for 152.217060 6 1/8 planer
You are correct, there is no replacement for part # OR90357, but if you have the original motor, I am sure that a local electric motor repair shop will be able to repair, or replace it. I'm confident that this is your best option at this point.
Nov 25, 2010 | Orion Craftsman Professional 8 in. Bench...
Smoke comes from around the switch when turned on & is slow to turn initially. mine is a fixed speed
If it is under warranty, take it back. If not then it is a simple matter of replacing the switch. Take off the cover and pull out the switch. Mark each wire as you take it off. Take the switch with you to the store. First try a hardware store, then an auto parts store. If they don't have it try Sears. They will probably be able order it. Make sure you have the model number of your grinder. It is on a data plate somewhere on the grinder. If Sears can't get it, try a wholesale electrical parts house.
Nov 19, 2010 | Orion Craftsman Professional 8 in. Bench...
I have a Craftsman Commercial 1/2 HP Bench grinder. When I turn it on It just hums. It doesn't turn. Can you tell me what is wrong and which part I need to change? Thank you, Marlan PS: I have misplaced...
The motor has a high spot on the armature causing the motor to stop rotating. The humming noise is the fields full of current which is making the armature to react to make this noise. For the money purchase a new bench grinder which is an easier fix than dumping money into your old one here
May 05, 2010 | Grinders
BROKE THE TOOTHED BELT ON MY BENCH COMBO GRINDER/WIRE WHEEL
I had the same problem, I went to a pawn shop, some times they have part for some of the items they buy . I wish you luck in finding one. it took me some time. hope you find one
Apr 20, 2010 | Orion Craftsman Professional 8 in. Bench...
Mar 02, 2010 | Delta Shopmaster 8" Bench Grinder
Porter cable router turning off intermittently during job
Hello. Yes it could be the extension cord or the outlet your pluged into or the feed speed of the cut.Try slowing the forward feed speed.
builderdale
Jan 24, 2010 | Porter Cable 75182 Variable Speed Router...
Grinder won't stay running
The capacitor is easy to change and can be matched once you remove it by any electronics parts house.
Nov 24, 2008 | Delta 23 884 8 Inch Bench Grinder Wheel,...
Wobble in disk
if this is disk type grinder make sure you did not knock the disk out of alignment when it fell off table if so remove and re-align or replace disk seen it before make sure
Nov 24, 2008 | Porter Cable Porter-Cable Variable Speed...
Grinders Logo
387 people viewed this question
Top Grinders Experts
Lawrence Oravetz
Vernon Taylor
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Grinder Expert? Answer questions, earn points and help others
