Question about Kenmore Ovens
Oven is overheating
My oven is getting very hot regardless of the temperature I select. I installed a new temperature sensor but that did not fix the problem. any other ideas?
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 650 Answers
If it has an electronic control there could be a welded contact on one of the oven relays causing the element to stay energized. A rare thing could be a shorted element that is getting a ground current bypassing the control but this usually will stay on even when the oven is off.
Posted on Mar 02, 2014
  • 274 Answers
SOURCE: Main Oven Overheating
Try putting thermoter in oven take off main dial you well see a small screw ajust slowly and check every 30min.tell temp is correct.and put dial back on
Posted on Jul 26, 2010
Testimonial: "Thanks, will give it a go. "
  • 1314 Answers
SOURCE: Oven Overheating with Fault Code F1 displayed after reaching temperature.
it varies first thing to do is check the connections if there is a plastic ribbion on yours can clean it with a pencial eraser unplug the wires and plug them back up a couple of times in case there is some restiance there now by sensor i assume you are talking the oven probe some where on your range you will find a techsheet that will tell you how to ohm the probe and they dont always
show the right code that should help let me know what you find ill be here
Posted on Jan 24, 2008
revamos
  • 16 Answers
SOURCE: Built in oven gets too hot
sounds like your thermostat is bad not sensing temp
Posted on Apr 19, 2008
SOURCE: oven overheating
I have just purchased a new thermostat and installed it. The oven now works fine and the heat light cut in and out showing temperature is being controlled.
Posted on Sep 03, 2008
  • 3 Answers
SOURCE: Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Posted on Sep 23, 2010
After running the lower oven "self-clean" function, the lower oven does not get hot. Upper oven still works fine.
Try the heating element, it could be open. Also check to see if it is getting voltage.
Nov 23, 2014 | Ovens
Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Nov 10, 2012 | Neff Ovens
Troubleshooting frigidaire oven
Too hot of a temperature - Check RTD sensor probe and replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive
Sep 03, 2012 | Frigidaire Ovens
Oven overheated, F2 on display
Replace your oven temperature sensor.
F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor
Sep 10, 2011 | Maytag 27" Built-In Double Electric Wall...
Receiving a F 10 message
F10 error code means "runaway temperature condition"
If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor and control checked.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven. Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven. Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms. The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website.
Hope this helps.
Apr 25, 2011 | Kenmore 47833 Electric Single Oven
Amana Self-cleaning Oven flashes F2 and F3 and beeps. It doesn't get real hot. Although it does heat up not the appropriate temperature.
Hi, F2 error code on the Amana Oven means "Oven too hot" You have to replace Oven temperature sensor to fix it.
F3 error code means "Open or shorted oven temperature sensor". Yo also have to replace Oven temperature sensor to fix it.
Summarily, both code has to do with the temperature sensor which you need to replace...
Oct 23, 2010 | Amana Ovens
F2 f3 starts beeping when using stove or oven
F2
Oven temperature too hot
Check and replace oven temperature sensor (RTD).
F3
Open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
So i suppose its a sensor replacement is necessary.These are the fault code explanations by frigidaire.good luck with the machine.Please do post results and comments.
Apr 15, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
Oven overheating
Jun 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Ovens Logo
49 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
