Question about Paoli Furniture
Side desk writing board is stuck - Paoli Furniture
I need assembly instructions for the office max writing desk with hutch
I called the 800 # and they immediately emailed a pdf file of the instructions.
1 800 254 0315
Mar 14, 2013 | OfficeMax Illustra Desk with Hutch OM02491
H08882ROTX sei lattice
The drawer was very hard to place in the slider runners, took 20 mins to get it in without it locking and getting stuck. Please note the small grayish tabs in side both slider runners, very hard to press theses tabs and see them but these tabs do release the drawer from being locked when you only have it half way in the slot it goes in.
Mar 08, 2013 | Southern Enterprises Lattice 48 in....
How can I tell if an old table I inherited is a writing table or a drafting table?
These two tables usually look very similar. If the drafting table was at a flat setting with the height set at regular desk height (maybe 74 cm) then it looks just like a writing table. The way to tell if it's a drafting table is if there is an edge on one of the sides. The edge was used to stop things from sliding off the table when the table was at an angle and it would sometimes hold writing tools.
Jan 03, 2013 | Furniture
The top of my desk is not smooth and it makes writing difficult. What can I do?
You can either buy a plastic/glass cover to fit the top of your desk and cover the surface, or you can fix it yourself with a little sanding and varnish. Here's a site that can take you through the necessary steps.
http://www.ehow.com/how_7862611_can-seal-top-writing-desk.html
Aug 15, 2012 | Furniture
Is it ok to construct a desk from particle board?
You can construct a desk from particle board; however I would advise against it. Desks constructed from particle board can break very easily.
What is a writing desk?
A writingdesk is office furniture that's traditionally been used for writing letters, byhand ofcourse. These desks have been used at homes since the late 19thcentury.
Jul 25, 2012 | Furniture
I have a acer travel mate laptop , on the desk top the desk top bar which usually is on the bottom has now moved to the left side of the screen, how do i bring back to normal
click on start button in key board press alt space in displayed options select move press down arrow key to move your task bar to down
Sep 11, 2010 | Acer Computers & Internet
My pen writes even if it's hovering over the board. =[
I had this same problem. I found my solution on here, but i don't know if it will work for you. Take the pen and hit the head of the pen into your hand 5 times (pretty hard i hurt my hand while doing it but not too hard) and then do the same with the eraser. It worked fine for me afterwords. Something about humid weather and the sticking of the pressure thing in the pen. I hope this helps
Apr 01, 2010 | Wacom Intuos3 Graphic Tablet
Furniture Logo
Top Paoli Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Paoli Furniture Expert? Answer questions, earn points and help others
