Home | ASUS | P5VD2-MX SE Motherboard | The driver of my dvd is ...
ASUS P5VD2-MX SE Motherboard
Problem for ASUS P5VD2-MX SE Motherboard
The driver of my dvd is not there my dvd is not
By usenorok on Jun 08, 2009
the driver of my dvd is not there my dvd is not reading
Solution #1
posted on Jun 08, 2009
Not Rated)
ebay312
Rank: Guru
Rating: 86%, 61 votes
The drivers for e-IDE and IDE drives are built into all operating systems. If your drive is not showing up in your My Computer window, then the problem is most likely not a driver issue, but either a bad drive (sometimes happens), or a bad connection.
Double check the IDE ribbons that connect your device to the motherboard and restart the computer.
However, if your system is using SATA connections, you may actually have a driver issue. It is unlikely, however, that a driver issue with a SATA connection would "occur" after you had been using it. If you recently installed the drive via SATA and you hadn't had a SATA driver previously, then you may have a driver issue. You can check for drivers from the manufacturer's website (of the DVD drive).
Good luck
tony
Was this helpful?
Yes
No
Popular Solutions for ASUS P5VD2-MX SE Motherboard
Questions and Unsolved Problems for ASUS P5VD2-MX SE Motherboard
Do you recommend ASUS P5VD2-MX SE Motherboard?
Answer
Answer
ecs geforce 7050 v2.0 mb has ECS geforce 7050m-m v1.0 bios 64-0100-000001-00101111-010509-ATHLON64
Answer
Dear sirs I had a hardware defect that can be defined as a component severely damaged by little fire... (More)
Answer
Report abuse posted by lanang22game on Mar 29, 2009 No Sound in Vista Ultimate Mobo P5VD2-MX SE... (More)
Answer
merhaba anakartim hdd usb gibi goruyor. bunu nasil cozerim
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASUS P5VD2-MX SE Motherboard:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14051
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
