Question about Element Electronics E1023PD 10.2 in. Portable DVD Player with Screen
Won't play DVD says Invalid disk - Element Electronics E1023PD 10.2 in. Portable DVD Player with Screen
My ilo dvd R/P will not record and keeps saying invalid disk,
TILO DVDR04 PLAYER RECORDER THE DVD RECRDER IS IT SPECIFIC TO THE DVD RO4 CAN IT BE REPLACED WITH ANY PLAYER BURNER IT SEEMS TO PLAY NORMALLY.
Mar 08, 2010 | iLO DVDR04
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
The file number 1 has invalid format
You Could:
1) Check that your DVD reader is working (use another disk).
2) Check the region code for the disk (most likely reason).
3) Take it to the shop you brought it from.
Apr 15, 2009 | HP Compaq 6720s Notebook
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
Recorded dvd's won't play on other dvd players Toshiba d-r410
You can play these recordings without finalizing them in the D-R410, but if you want them to play
in other DVD players, they need to be finalized. See pages 28 to 32 in manual. If you want to
finalize the disks you've already made, follow the directions on page 32.
Jan 05, 2009 | Toshiba DR410 DVD Recorder
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
If the unit is showing "invalid disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. Our warranty is 90 days from the date of purchase. If you've had the player longer than 90 days, I regret to inform you it is out of warranty.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Jan 02, 2009 | Coby DVD-209
Invalid disk
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's but avoid memorex brand. Usually any other cheep brand will work.
May 04, 2008 | Gateway AR-230 DVD Recorder
How to make wmv files to get play on this DVD player.
WMV won't play in the DVD, convert it to MPEG or DIVX.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
Element Electronics E1023PD 10.2 in. Portable DVD Player with Screen Logo
18 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
