Question about NEC PABX SL1000
Console pabx connectivity - NEC PABX SL1000
Uniden troubleshooting
was the old phone connected to a Private Automatic Branch Exchange P.A.B.X like for example a comander system if so the new phone would have to be a PABX type phone extention type. I suspect the Uniden phone is not compatible with the PABX extension socket.
http://www.excitingip.net/291/ata-analog-telephony-adapter/
http://www.kosmaz.com/ata.htm
http://www.cisco.com/c/en/us/products/collateral/unified-communications/ata-186-analog-telephone-adaptor/product_data_sheet09186a008007cd72.html
I do not know what phone system you are using you might want to find out the model number of your PBX device and research if it uses VOIP = I can only guess that this is the situation
Sep 01, 2014 | Radio Communications
Pc console for panasonic pabx tde 600 e
Google the bolded words below exactly as they are.It should lead you to a download source.
- Panasonic Unified
Maintenance Console UPCMCv7.1.1.7
Sep 06, 2012 | Panasonic KXTDE600 KX-TDE600 KX TDE600...
How i can install external page port of a pabx Norstar with output of 600ohms to the input Radio shack 250 Watts PA.
Connect Nortel PABX external page port output to the amp input.
Either by phone plug or RCA connector, any of the two will work.
Apr 19, 2011 | Radio Shack 250 Watt PA Amplifier...
How do I update the time on the panasonic kx-t7730
that is not pssible to set from telephone
there is a PABX device (panasonic kx-tes824 ) fixed in wall
from that PABX check 101 extension number (maybe 10, wich phone connected jack1 )
from there is only you can program
Please let me know this useful
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
Digit 3 has been restricted by console with 03 dialing
enter system programming Pres *#1234 (default password)
scroll using volume keys and change the COS class of service to either 1 or 64
Apr 14, 2010 | Panasonic (KX-TDA200)
I need new panasonic kx-tda 600 pabx software?
KX-TDA100 Maintenance console found at www.wanetelecoms.com
KX-TDA200 Maintenance console found at www.wanetelecoms.com
KX-TDA50G Maintenance console found at www.wanetelecoms.com
Panasonic Unified Maintenance console Version 7.3 found at www.wanetelecoms.com
Mar 04, 2010 | Panasonic (KX-TDA0104) (KXTDA0104) Power...
Interconecting 2 Panasonic KX-TDA 200 & KX-TDA600
You are asking for some very advanced setup features, as far as connecting them you need the IPGateway cards. They are cat5 cards that will do the trick. However programming the setup to do what you want will be VERY time consuming and not to easy to walk someone through. On-site tech is highly recommended for that much programming and work.
Feb 24, 2009 | Panasonic KX-TDA0410 (KXTDA0410) Network...
NEC PABX SL1000 Logo
20 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
