Question about Xerox Office Equipment & Supplies
Download mode press stop key
Workcentre 3210
My scanner xerox 3210 scanner locked and I con't find the unlock switch
It's located where the paper comes out above the toner door. It's on the top side on the left. Put your hand inside where the paper exits on the left side and it's above your hand.
Jun 27, 2016 | Xerox 3210/N WorkCentre series 3210/N MFC...
HOW TO RETRIEVE ITEMS IN MEMORY IN XEROX 3210/3220 WORKCENTRE FAX ?
dear Is there any error or masage disply on the screen. Pl. revert back.
Thanks.
Dec 18, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
Would you please tell me how to reset xerox workcentre 3210 cartdridge chip?
Hi Marco,
They have a chip in them and can't be fooled so to speak by topping them up.
You can get toner and chips off ebay if you do a search for your model...
refer to link for an example...
http://www.ebay.com.au/itm/Hi-Yd-Toner-Refill-Reset-Chip-for-Xerox-WorkCentre-3210-3220-106R01487-/261253227411
Oct 26, 2014 | Xerox WorkCentre 3210 - Multifunction -...
Xerox WorkCentre 3210 invalid toner
Verify you are use OEM Xerox Toner. If so, try reboot the unit, take out and reseat the toner. If that doesn't fix it you'll have a bad main board and will need to be replaced.
Sep 12, 2013 | Xerox WorkCentre 3210 - Multifunction -...
Install xerox 3210 wimdows 7
try
http://www.support.xerox.com/support/global-printer-driver/downloads/enus.html?operatingSystem=win7
Dec 28, 2012 | Xerox WorkCentre 3210 - Multifunction -...
Would you please tell me how to reset xerox workcentre 3210 cartdridge chip? I am trying to recharge it but my printer says "no toner" or "toner low" ... Tks in advance. João (jobarbosa9@yahoo.com.br)
enter tech mode by : menu # 1934 menu - nothing else
run downl3210.bat (firmare update)-you can find it in a lot of places wait aprox 1 min
enter tech mode - data setup
Sep 13, 2010 | Office Equipment & Supplies
WorkCentre 555 Fax Drum
This will reset it for you. strange !!!!!
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode
Mar 14, 2008 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Xerox Workcentre Pro 416 P
This would be the first thing to try..
  • Press the 0 and 8 keys simultaneously and switch on.
  • Input 400 using the numeric keys, and press the enter key.
  • Change displayed status counter to 0, and press the enter key.
  • Switch the machine off then on. Check that the machine returns to the normal standby mode. If the machine does not return to normal standby mode, perform the following checks.
  • Feb 18, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
    49 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    CheckitRight
    CheckitRight
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
