Question about LG Washing Machines
Where can a get a Lint Filter for my LG WF-T552TH
I am having difficulty getting a replacement lint filter in New Zealand, can you help?
cactus bob
  • 267 Answers
SOURCE: looking for the lint filter
you did not give me a mod # of your washer .... so i will go through the history of the lint filter 1955-1964 the lint filter was on the right side under the lid , twist knob and pull screen out 1965-1986 lint filter was self cleaning mounted under the washer 1987 -today there is no lint filters any more ..... lint filters where used when people hung the clothes out on the line .... today most people use a DRYER that has the lint filter in it .... i hope this helpes ....... if you are going to rate this please rate this 3 or 4 stars , that will keep me in the paid answer department . thanks
Posted on Apr 01, 2009
SOURCE: remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Posted on Jun 07, 2009
SOURCE: Lint Filter in Whirlpool Agitator washing Machine
I have a regular top loader and the lint filter is on the underside of the inner tub. You have to remove the inner tub to get to it. You might be able to find a service manual explaining this at appliancejunk.com.
Posted on Dec 09, 2009
  • 159 Answers
SOURCE: Where is the lint filter located on this washer?HLP21N
Hi.It may be that these machines dont actually have a lint filter,they are making alot of them without lint filters now days.There would be a button trap down at the side or the rear i would imagine for cleaning out debris such as coins,hair pins,Etc.
Posted on May 29, 2010
Testimonial: "Thanks!I will check it out."
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
I own a lg turbo deluxe wf t7517te machine After the machine has washed the clothes it doesnt drain it Please fix my problem asap
Sometimes lint and other debris can collect in your drain pump filter. Keep things running smoothly by cleaning your drain pump filter occasionally.
  1. Open the drain pump filter cover by pressing on the center tab.
  2. Pull out the manual drain hose to the left of the filter cap and use a small bowl or pan to drain out any residual water (approximately 2 cups) that is remaining in the drain pump.
  3. Place a towel down on the floor to catch any left over water and remove the drain pump filter, by turning it counterclockwise.
  4. Remove any lint or items trapped in the filter by tapping it out into the wastebasket, and rinse it thoroughly with warm water.
  5. Replace the plug at the end of the manual drain hose and place it back into the holder. Then reinsert the filter into the drain pump opening and turn it clockwise to secure it back in place.
Apr 04, 2014 | Washing Machines
Lg fuzzy logic manual wf-t552th
I have an LG WF-T502C T552.
It makes a loud squeal noise on the spin cycle.
I am thinking of replacing the belt. Is it possible it could be the bearings or the transmission?
Dec 24, 2013 | Washing Machines
Lint is stuck in door seal and clothes are not drying
sounds like the lint filter is clogged up, replace it with a new one if possible or give the old filter a good wash, let it dry and try again
Jun 03, 2012 | LG DLE5977 Electric Dryer
Lint filter on LG DLEX2901V sticks up in the corner and catches clothes
Look familiar? LG dryer model DLEX3250W. Lint frame does not fit the slot anymore. NOT BECAUSE OF EXTRA LINT it's because the frame is warping.
Dec 07, 2011 | LG DLEX2901V Dryer
I have th lg dlgx3002w dryer. the garments get hung up in the lint filter and tears the garment. the edge of the filter is slightly melted. what causes this and how can i keep this from happening again?
I had the same problem. My LG dryer lint trap did the same thing and I ordered another one for replacement. The new lint trap is not rounded on the batton on the corner below where it got bent up and snagged your clothes. The new one is cut at a slight 45 degree angle. I believe that LG changed the design a little so clothes won't get hung up on that edge. Go to this site and you will see a picture of the replacement part. http://www.appliancepartspros.com/lg-dryer-lint-filter-adq56656401-ap4457244.html
Feb 06, 2011 | LG DLE5977 Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Gasket for dryer lit catcher is coming off
The gasket on the lint filter is not very important, but you can get a replacement lint filter. There is a screw at the center bottom area of the lint filter area which can catch on the gasket. If you replace it with a shorter screw or remove it, grind it down a bit, and replace it you will help avoid a repeat condition.
Jan 02, 2011 | LG D2526 Gas Dryer
Brand new dryer. **** went down lint filter area
You may have to remove the front panel to enter the air passages and blower fan. Try feeding a vacuum cleaner hose (remove the metal hose end) into the area behind the filter to see if can pick up whatever dropped into it. Hope this helps!
Apr 12, 2010 | LG DLE2050 Dryer
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Washing Machines Logo
26 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
