Question about Photography
Need a quickrelease for my solidex vt86hq, where can i find one
Head for fluid solidex tri pod
Solidex is not a tripod for which parts can be gotten. Most of the Solidex tripods do not have removable heads. Try anther brand. You can find a bunch of very good tripods at: itripod.com UI like the Sirui brand
Dec 04, 2012 | Photography
I am looking for quick release plate for a Radio Shack RST-84V tripod made in the 90s. I looked all over (local radio shack stores and corp. head quarters) but no one has any info. Finally I came across...
I found this tripod, new, on Ebay. It looks like it would serve your purpose. I'll keep checking for you, but take a look at it- it was posted on the 22nd of May, so you have plenty of time to check it out and buy it, if you choose. Good luck, hope this helped!
May 23, 2010 | Cameras
Solidex po#9976-325 cat#161-1615 need quick change shoes
As far as I know Solidex is out of business and since most of there parts are not standard to the other major manufacturers you should either buy a new tripod or search for the same (exact same) model on ebay or craigs list to find the same model and use it for parts.
Jan 06, 2010 | Photography
I need the quick release plate that holds the camera on the tripod for the Solidex tripod # VT-92XT model. Where can I find one? I live in the Seattle, WA area. Thanks.
As far as I know Solidex is out of business and since most of there parts are not standard to the other major manufacturers you sould either buy a new tripod or search for the same (exact same) model on ebay or craigs list to find the same model and use it for parts.
Dec 03, 2009 | Photography
My handle broke on my Solidex Model VT-90HQ tripod and I am trying to find part.
Nov 27, 2009 | Photography
Tripod
If you have not found the part for your tripod you are looking for, I have the whole assembly complete, still in the original box.$50 and it's yours.
Jan 01, 2008 | Photography
Solidex camcorder tripods
OKAY!! Thanks to the reply of "Baldwink", I was able to locate the product he suggested here in the U.S. from several dealers. This is the plate that mounts to the camera and allows easy removal/attachment to the tripod.
For the Solidex VT-90 tripod (the one I have and may fit others), order the Cullman CU-40470 Quick Release Plate. This is also described as the "Cullman Medium Quick Release 42mm" plate.
If you don't have the VT-90, measure the shoe plate area on top and remember that there will be at least one beveled (angled) area. Mine measured exactly 42mm square, so I am confident that the Cullman plate will fit. Also, the standard thread size for camera mounting is 1/4", but there are some cameras that use 3/8", so you might want to double check your camera for this spec.
I googled "cullman 40470 quick release" and found several U.S. dealers. The best price was from Adorama.com at $14 plus $5 ground shipping. Some dealers want as much as $33.
After nearly 20 years, I can use my Solidex VT-90 again!
Nov 15, 2007 | Photography
Photography Logo
62 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
