Question about Amana ARB8057CSR Bottom Freezer Refrigerator
Horse power softdrinks cooler
What is the engine capacity horse power for a 351 ford cleaverland .
351 "C" 4V 1970-1973 Cleveland
http://www.carmemories.com/ford-engine-specifications/351-engine-specs/351c.html
would have thought engine capacity would be what they wanted
351 cubic inches which converts to 5.75186 litre capacity
horse power in the link above is 300 BHP (brake horse power)
I have no idea myself but found the car memories web site that states the engine specifications and I hope it is correct and matches your engine ?
most likely it would be rounded up to a 5.8 litre capacity
Jul 07, 2017 | Ford Cars & Trucks
Tip
COOLER
THE WHEATHER MIGHT BE TO HOT OR THE LOCATION OF THE REFRIGERATOR IS HOT TRY TO CHANGE THE COMPRESOR INTO HIGHER HORSE POWER COMPRESSOR
on Jul 03, 2010 | Refrigerators
How many horse power is 277 cc and 357 cc in small engine snow blowers
277 cc is equal to between 7 and 8 horse power
357 cc is equal to about 13 horse power.
Brigs changed their rating several years ago when every thing went metric. I googled this information.
Jan 01, 2017 | Garden
What does the 5hp mean
it is how much power the motor has. In the old days people travelled on horses . One horse produced one horse power. So if you had a buggy with 5 horses attached to it you had a five horse power buggy. So your schredder engine has the equivalent power produced by five horses.
https://en.wikipedia.org/wiki/Horsepower
Jun 29, 2015 | Troy-Bilt Heavy Machinery
205cc =what horse power
1 hp= amount of work perfomed to raise 33,000 lbs 1 ft over 1 minute.P.L.A.N is mean effecftive Pressure x the Lenght of stoke x the mean effective Area of the piston x the Number of Strokes per minute= horse power..so about 9 horse power 10 at sea level at 15C and 2800 rpm
Aug 21, 2014 | Garden
We bought a slushmagic yesturday, i have put 2 different types of soft drink in it (not diet) and its just not getting slushy, manage to get a slight slush to it but takes well over an hour. Fleur
put ur softdrink in first, then in the ice compartment, put bout a dozen cubes, then a generous amount of rocksalt, then more ice, then more rocksalt. U have to use more than what sunbeam recommend. The softdrink should be pre-chilled in the top of the fridge overnight so its about 3 degreees
will take about 7 min for the slush to appear. if not , then use MORE rocksalt.. IT DOES WORK
Nov 08, 2010 | Sunbeam Microwave Ovens
I need an owners manual for my master cool. Can you help. Also, what size motor pulley is required for a 3/4 horse motor and a 1 horse motor?
Hello You need the SHAFT diamater size on the motor.And they have an ADJUSTABLE pulley to set.Bring the old one if possible.
Sep 15, 2010 | Mastercool 67680 Evaporative Cooler Air...
When the wind blows my motor stalls and blows the breaker. Please reply slowly as my english in not so good.
The horse power of the motor is either to small or you can also adjust the motor pulley, loosen the allen set screw on the motor pulley, turn it in one or two full turns. The readjust the belt, there will be less airflow, but the amprege draw on the motor will be reduced.
Have a great day.
Sincerely,
Paul Gibson
Apr 30, 2010 | Mastercool 67471 Evaporative Cooler Air...
80 SERIES OVER HEATING UNDER LOAD
put electric fans bigger radiator .tranny cooler kit.this might help some you might need bigger engine more horse power.
Apr 10, 2009 | 1994 Toyota Land Cruiser
How to improve power without buying a new truck
a few things you could do would be to turn up the pump, bigger injectors, add a turbo and after cooler, and differents gears in the differentials and/or transmission, rear axle airbags would improve your ride quality too, also i beleive its a 444 cu. in. engine if its an international 7.3( ford 7.3 )
Mar 30, 2009 | 1988 Ford F 250
Amana ARB8057CSR Bottom Freezer Refrigerator Logo
15 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
