Question about Motorola Mobility H730 Bluetooth Headset
Motorola h730 after factory reset will not stay paired after closing and opening again
  • Official Brand Answer
  • 3,100 Answers
Delete the pairing on the phone and then re-pair. Also ensure your headset is fully charged. It should autopair with your phone after a reset when you open boom if phone has bluetooth turned on and is in range.
Mark
Motorola Support
Posted on Jul 31, 2014
4 Suggested Answers
SOURCE: My Motorola h700 bluetooth will not pair
Rest assured that the drop did not cause this.  There is a general problem with these H700's.
Press the multifunction button until the led turns purple.  Keep it pressed in while you flip the arm open.  The arm needs to be kept fully extended to keep it in pairing mode.  If you succeed in positioning the arm correctly, a steady blue light will be on.  If the light goes off...close the arm and try again.
While in this mode...execute the pairing procedure from your phone...it should find the H700.  The default key is "0000".
Posted on Oct 25, 2007
rockfixya
  • 679 Answers
SOURCE: Motorola Headset Out of range...
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HS815 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 22, 2009
  • 65 Answers
SOURCE: Light won't stay purple even when boom closed & button held
Depending on the phone... try and remove the current bluetooth device, if there is any. Close the headset. Go to the phone and choose discover, or search. Open the headset and press and hold the big button. It should then turn purple and should be recognized.
The boom should be open when you press the button.
Also make sure the battery on theheadset is charged before doing this.
The passkey will be 0000, four zeros.
Posted on Jul 31, 2009
Motorola H730 will not turn on even though it is fully charged
Karen-
Are you getting a steady blue light when you follow the pairing procedure? Or are you unable to get it to stay on stead?https://www.motorola.com/moto_care/manuals/BT/H730_QSG.pdf
Mark
Forums Manager
Dec 02, 2014 | Motorola Mobility H730 Bluetooth Headset
Why motorola h730 blue light stays on
It is wanting to pair with your phone. Pair with it and then it will blink.
Jun 26, 2014 | Motorola Mobility H730 Bluetooth Headset
Intermmittment access with ios7
I would unpair and try pairing again. Ensure you open the boom. It will not connect if the boom is closed.
Mark
Motorola Support
Apr 03, 2014 | Motorola Mobility H730 Bluetooth Headset
MY BATTERY DIED, I CHARGED IN CAR AND NOW I CANNOT GET ANY VOICE PROMPTS ON THE HEADSET TO WORK AND IT WILL NOT PAIR
I think I am having the same issue:
When you open the H730 up do you hear beeping noise instead of a womens voice. Also does it stay on until you open it for a second time.
Sep 03, 2013 | Motorola Mobility H730 Bluetooth Headset
My Motorola H730 won't stay charged
Jess
Are you charging with boom closed and closing boom when not in use?
Mark
Motorola Support
May 29, 2012 | Motorola Mobility H730 Bluetooth Headset
Motorola Mobility H730 Bluetooth Headset Logo
160 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
