Question about Sony CDP-CX400 400-Disc CD Changer
Plays OK for hours, then stalls on loading
Using the 400 in Megacontrol mode with a CXP200, both machines work fine but eventually the 400 locks itself into blinking mode and will not respond to commands. When powered down it briefly flashes LOADING ERROR. On power-up it works again. Both the 400 and the 200 are set on ALL DISCS - SHUFFLE - REPEAT as a cheap broadcast automation system. Opened it up and air-blasted the lenses to no avail.
2 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: My Sony 400 cd player will not play any cd's.
Your optics are either Really Dirty, or out of line and you would need a replacement optic pickup. If you are mechanically inclined, it's not a difficult repair and parts can be purchased thru lots of sites. First things first, pop the top and use "Dust-OFF" in the main chasis, it gets bad! Next, if you have a good CD/DVD player cleaner that uses fluid, run it thru a couple times then test any disc. If you don't have one, just about any convenience store has them. Just make sure it uses fluid!. If you still have an issue. post a comment and I can pdf you the schematic of the unit. it's pretty easy to read and follow if your a little more than a novice with electronics. Hope this helps
Posted on Jun 01, 2011
Have a new ge WCVH6800 front load washer. Power was interrupted during washing cycle. Machine now stays in drain mode, stops after 3 minutes, door unlocks and start/ pause button flashes. How do you...
Hello there and welcome to fixya
You may want to try unplugging the machine for a minimum of 2 hours to let the internal cpu to reset itself then plug it back in then press the mode button then try to lock the door and it should be ok after that ok please inform me how this goes there is more we can do for this ok
Best regards Michael
Feb 28, 2010 | General Electric WCVH6800J Front Load...
Machine is dead and door is locked
Check fuse in wall plug OK then:-
Pull out wall plug remove the top & possibly you can reach down inside the front & operate the release catch by hand
Nov 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hour glass sign on the screen of my MP3. won't go away and MP3 won't start working. The hour glass sign just stays on the screen.
I have a Craig CMP616F MP3 player. In "Set Up", After I set the "online mode" to "Media Device" from "USB Disk", it was working ok until I loaded Apple iTunes. When Apple iTunes attempted to load, it crashed! Flashing start up screen, blue with Hour Glass, then blank out, attempt to restart and the same thing, blue screen with hour glass. There is no known reset proceedure at this time, I started it, let it run and recycle endlessly until the batteries expired. Not recommended, because of battery life, but this did reset this model. Success! A drastic step for the irrecoverable MP3. When I used a standard charger 110v Ac to USB (wall current) it started up, no lost files! Lucky, maybe, I hope this will work for you if you haven't thought of it.
Nov 19, 2009 | Audio Players & Recorders
400 Eiger ATV, starts and runs fine, stalls the
If 2 stroke check crank seals, check plug cap for proper resistance,check for good fuel flow to carb.Spark should jump at least a 1/4" gap,NOT JUST the .030 or plug gap.
Sep 08, 2009 | 2004 Suzuki DR-Z 400 E
Washer whirlpool cabrio message code f50,washer
F50 - This is a motor stalled failure. If this persists you will eventually need to call in a service engineer to repair it as the machine will eventually stop working altogether.
Sep 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Akai MPC 400 Plus Drive Crash
u go to dos mode to using boot disk or ,press F8 after post screen,then select dos mode and type in dos mode as 'chkdsk'
follow onscreen instruction ,thats all ,thats ok ,restart the pc then try again ,thats working i hope
regards
prasanna
Mar 04, 2008 | Akai MPC-4000 Plus Production Center (w/80...
Bad playback
have same problem, get dvd error message "disc error unable to read disc
Oct 03, 2007 | Samsung DVD-V1000 DVD Player/VCR
I need help
un plug your machine for an hour if you can open the door open it and then put the machine plug back in with the door open keep it open till the machine comes on then put the program to what you want and then shut the door it then should be ok its called a reset try it hope this solves your problem
Aug 26, 2007 | LG WM2077CW Laundry XL Front Load...
Teac dvd player
how old is your machine? if old enough isuggest you change the lens and try if it can load faster than before
Aug 01, 2007 | Teac DV-3500 DVD Player
Sony CDP-CX400 400-Disc CD Changer Logo
65 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
