Heaters
Problem for Heaters
Generic problem for all Heaters
Vulcan oil heater won't restart
By cwangel on Jun 08, 2009
the heater ran out of oil. We refilled the tank but it won't restart. The oil filter under the outside oil tank is letting oil through OK (is not blocked). Do I need to bleed something?? This happened last time we ran out of oil, so we got the heater serviced, and the repairman said that the filter under the tank was blocked
Solution #1
posted on Jun 08, 2009
Not Rated)
ac fixer
Rank: Guru
Rating: 86%, 42 votes
if it is a two line system the pump should prime its self on a one line system there is a bleeder screw 3/8" on the pump but remember every time the reset is reset the pump could be adding fuel to the burner so make sure it is getting spark you should here it hope this helps also make sure you have fule not water in lines
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
best heater for a 5,000 square foot monolithic dome
Answer
What is the best portable heater for a 700 sq ft area
Answer
does the heatingroomthermostat have tobe installed by plumber or electerician
Answer
Could anybody please provide me with instructions on how to carry out a basic service on my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heaters Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
