Viewsonic vs11531 What remote will work with this model. pg
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: All of a sudden, my Viewsonic VS11531 screen went
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Parts for your monitor:
http://www.google.com/search?q=Viewsonic+VS11531&hl=en&prmd=ivns&source=univ&tbm=shop&tbo=u&sa=X&ei=H6uwTbfFOYWUtwefksCDDA&ved=0CCsQrQQ
Posted on Apr 21, 2011
Viewsonic vs11531
See this... http://www.badcaps.net/forum/showthread.php?t=15135
Just don't pay more for a repair than a new one would cost.
Aug 04, 2014 | ViewSonic VX2835wm Monitor
My viewsonic model # vs11531 wont power up,what can I do?
Unplug the power, then plug it back in.
If that fails, try a different outlet, and bypass your surge protector.
If that still fails, check viewsonics website (http://www.viewsonic.com/us/) to see if it's still in warranty. If you register your item, sometimes they'll cover the repair or replacement fees.
If that fails, and it has been not long, you can contact where ever you bought it from and hope for a replacement.
Mar 23, 2013 | Televison & Video
Will any ViewSonic remote control work on any ViewSonic tv
No, most of them you will have to program it to work with other model of Viewsonic TV.
You have to go to WWW.VIEWSONIC.COM to the get the info for your model of the remote you have.
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Oct 30, 2011 | ViewSonic N3251w 32 in. LCD HDTV
I have been given a viewsonic hdmi tv & need the remote to operate it properly. the model number of the tv is vs11527-1e , can you help me ?.
Howdy, I have found the number and email for Viewsonic customer service, here it is:
Sales Information
T: (888) 881-8781
Salesinfo@viewsonic.com
They should be able to get you a proper remote. Hope this helps:)
Aug 27, 2010 | ViewSonic Televison & Video
I have a Viewsonic N2060w-1M TV but I don't have a remote. How to I program a universal remote control - Jenses -to work with my Viewsonic?
For the remote codes, Viewsonic does not have any since the universal remote comes furnished with a code book from the "MAKER" of that Universal Remote. I have heard that the Philips TV brand codes for universal remotes work on quite a few series' of Viewsonic TV's, so try those from your code book.
May 30, 2010 | ViewSonic N2060w 20 in. LCD Television
Codes for viewsonic TV remote
Yes you can purchase the remote from Viewsonic Online Parts Store or I have seen them for sale at remotes.com and that 3rd party store gives a 1 yr. warranty unlike VS 90 day warranty on the remote. As for the remote codes, Viewsonic does not have any since the universal remote comes furnished with a code book from the "MAKER" of that Universal Remote. I have heard that the Philips TV brand codes for universal remotes work on quite a few series' of Viewsonic TV's, so try those from your code book.
Jul 13, 2009 | One For All URC-4605 Remote Control
I have a Viewsonic VS11531 27.5 inch monitor I use a OmniView® PRO3 16-Port USB & PS/2 KVM Switch. The monitor has a res of 1900 x 1200 but when I hook it to the kvm switch the display will not...
In the link below, on page 9 of the PDF the maximum stated resolution of the KVM is Up to 1920x1440 @ 75Hz.
http://cache-www.belkin.com/support/dl/p75457_f1da116z_man.pdf
The monitor supports up to 1920x1200 @ 60Hz.
It sounds like there is an issue of synchronization between the monitor and KVM. This will force the monitor into a lower resolution to sync them. You may want to check with Belkin to see if there is a firmware update for the KVM. There may also be a driver issue with one(all) of the video cards on the system. I recommend updating the drivers on all affected machines with the monitor connected directly to the individual machines. Rather than using generic drivers, I would use the drivers downloaded from the manufacturer of video cards and from Viewsonic for the monitor.
Jun 28, 2009 | Belkin Computers & Internet
Remote code
I had the same problem with a Viewsonic N3735W LCD TV and Comcast Customer DVR 3 Device remote. I contacted Viewsonic and they gave me 11454 which works.
Dec 19, 2008 | ViewSonic N3735W 37 in. LCD TV
WHERE Can i get a viewsonic remote?
Try visiting the part store the following link, make sure you have the correct serial number. http://www.PartStore.com
Also to buy universal remotes try visiting http://www.ilektroniks.com
Thanks
Nov 21, 2007 | ViewSonic RLC-006 Remote Control
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
