Question about Music
Sustain pedals not working on a Kurzweil mark 10 didgital piano
Re Kurzweil Mark 11 digital piano, sustain pedals are not working.Attempted to reboot to factory default setting using two methods. Then removed pedal cable harness from of the pedal circuit board and the continuity on all wires was .6 ohms. Then tried pressing on the actual switches located on the circuit board with no success. Does this mean that the pedal circuit board will need to be replaced?
  • System TECH Feb 13, 2014
    Hi pianocntr1 , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
3 Suggested Answers
  • 5603 Answers
SOURCE: Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Posted on Sep 17, 2009
  • 5603 Answers
SOURCE: I Have a Casio Privia
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Posted on Aug 05, 2011
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
Apr 14, 2016 | Kurzweil Music
Kurzweil M1 digital piano is resetting (shutting down and turning on) on its own in the middle of playing.
You're correct, that's a power supply problem, but it may also be the power supply connector on the keyboard. If you have access to a voltmeter, check the power supply first.
Apr 06, 2016 | Kurzweil Music
Casio Privia 410r Piano soft pedal problem
The Casio Privia 410r has two pedal jacks at the back. One is the sustain pedal, the other is the soft/sus jack. Please use the other jack if you want to use sustain pedal. Only 1 of the 2 jacks can be used.
However, if you have the optional sp30a pedal which plugs UNDER the piano instead, then only can you have 3 different piano pedals.
May 18, 2014 | Casio Privia Px330 Px-330 88 Key Digital...
How can I repair my sustain pedal?
Odds are it needs replacing or a technician. Contact a local music store that sells Yamaha pianos or call Yamaha at 714-522-9000.
Feb 22, 2014 | Yamaha YDP223 Digital Piano
Replacing battery in kurzweil mark 12
As per the manual it says it is located near the power switch. You will need(as per the manual instructions): a screwdriver(Phillips head), a knife, a pair of scissors, and a pair of front end wire cutters as, when shipped from the factory, the three AA batteries were taped or cable tied as a shipping precaution(to keep them from falling out). ***WARNING: MAKE 100% SURE YOU HAVE BACKED UP ALL OF YOUR SOUND PATCHES ON A FLOPPY DISK BEFORE BEGINNING THIS PROCEDURE!!! ONCE YOU START THE REPLACEMENT PROCESS, YOU HAVE ABOUT 30 SECONDS BEFORE THE BOARD LOSES ITS CHARGE AND YOUR SOUND PATCHES GET ERASED FROM THE ROM CHIP.***
Make sure you have all of the needed batteries and tools before beginning.
Hope this helps.
Nov 23, 2012 | Kurzweil Music Systems Kurzweil MARK152I...
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
May 22, 2012 | Kurzweil SP3X 88-Key Stage Piano
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Kurzweil piano keys are clicking seems to be worn out.
I don't see you doing any damage by having a look but I would get a piano tuner or repairer in to investigate the problem expertly - no slight on you. But if your Church congregation depend on it it's well worth the money.
Good Luck
Sep 02, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Music Logo
166 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
