Washing Machines Logo
J
Joe Smith Posted on Feb 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I disassemble the clutch - Fisher and Paykel Washing Machines
Greg Stephen
Level 2:
  • Fisher and P... Expert 566 Answers
  • Posted on Apr 21, 2014
Greg Stephen
Level 2:
Answers
566
Questions
Helped
224825
Points
688
Removal of Clutch Mechanism (Spline Drive / Spline
Driven)
(a) Remove fabric softener cup undo wing nut and remove agitator
(b) Remove the 3 screws securing the spline drive to the inner bowl.
Reassembly:
Refit in the reverse manner. Ensure that the screws are tightened sufficiently with out over tightening.
1helpful
Disassemble clutch basket 2007 harley davidson evo sportster
I only have a drawing of a Sportster 2002, but perhaps it helps? c6119887-9e29-4c68-9662-7069343c05ad.png
Jul 27, 2014 • Motorcycles
Trans.center plate spring1989fxrs low rider
Are you asking about the clutch diaphragm clutch spring?
If so, then no, you don't have to disassemble the transmission to replace.
Polaris 330 mag, barely moves in reverse? possible ****** problems??
If the belt has been changed, the button ramps in the secondary clutch should have been checked. The secondary clutch has 3 ramps that tend to wear, and this will wear the clutch out if not replaced right away. To remove the secondary clutch (rear clutch) remove the clutch cover and belt. Remove the bolt from secondary clutch and pull clutch off. The clutch is on a splined shaft so a puller will not be necessary. To check the ramps inside the clutch, rotate the outer sheave clockwise while holding inner sheave stationary. You should be able to see the ramps, if not they have worn completely gone and the clutch will have to be disassembled. Check this and let me know what you find. I will be happy to assist if you need to disassemble the clutch, Daniel.
Jan 12, 2012 • Polaris ATV
My TB70SS cranks and runs perfect! The problem is the clutch seems to not engage. The head will spin at idle speed, but, when I pull the throttle trigger, it seems to bog a bit, and the head almost quits...
There may be an issue with the clutch or the clutch drum. Some disassembly may be required if the string head doesn't spin quickly when accelerating the engine. The clutch itself is threaded onto the crankshaft of the engine near the handle end and the clutch drum is screwed into the end of the crankshaft. If you can disassemble to that point, you will be able to diagnose your clutch problem...maybe it is worn severely and needs replacing.
Clutch is frozen from sitting in garage
This is a common problem that the clutch plates glue them selves together. You will need to remove the clutch outer case cover and disassemble the clutch and one by separate each plate re oil them and reassemble them.
Clutch pedal went to floor no fluid loss push rod disassembled
Hi:
If your clutch reservoir is still full, you have had a failure of either the clutch master cylinder, or the clutch slave cylinder.
Need to disassemble a Honda NXR Bros 125 clutch
you need to use a large air impact wrench
1998 kdx 200 clutch will not dis-engage when i pull clutch lever in gear will not roll with clutch lever pulled. how tight do i thighten the sprigns on the clutch?
The clutch's plates must be stuck.Disassemble them and renew if necessary.The clutch lever should have 3mm freeplay and the spring's bolts should be tighten at 14Nm.
1helpful
My 2001 lincoln ls wont go into 4th or 5th gears. Took it to a trans shop and they recommended a rebuild for 3000+ dollars. But Ive been reading that alot of lincolns with the same problem getting err
call your dealer to get an estimate too.
Shift Patterns Upshifts
Transmission upshifting is controlled by the powertrain control module. The PCM receives inputs from various engine or vehicle sensors and driver demands to control shift scheduling, shift feel and torque converter clutch (TCC) operation.
The PCM has an adaptive learn strategy to electronically control the transmission which will automatically adjust the shift feel. When the battery has been disconnected, or a new battery installed certain transmission operating parameters may be lost. The Powertrain Control Module (PCM) must re-learn these parameters. During this learning process you may experience slightly firm shifts, delayed, or early shifts. This operation is considered normal and will not affect the function of the transmission. Normal operation will return once these parameters are stored by the PCM.
Apply Components Band — Overdrive
For component location, refer to Disassembled Views in this section.
During 2nd and 5th gear operation, hydraulic pressure is applied to the overdrive servo.
  • This pressure causes the piston to move and apply force to the band.
  • This action causes the overdrive band to hold the overdrive drum.
  • This causes the overdrive sun gear to be held stationary through the adapter plate and the overdrive drum.
Band — Low/Reverse
During 2nd gear operation, 1st gear operation and reverse, hydraulic pressure is applied to the low/reverse servo.
  • This pressure causes the servo to move and apply force to the low/reverse band.
  • This action causes the low/reverse brake drum to be held.
  • This action causes the low/reverse planetary assembly to be held stationary.
Band — Intermediate
During 3rd gear operation, hydraulic pressure is applied to the intermediate servo.
  • This pressure causes the servo to move and apply force to the intermediate band.
  • This action causes the direct clutch drum to be held.
  • The intermediate band holds the intermediate brake and direct clutch drum to the case in 3rd gear.
  • This causes the input shell and forward sun gear to be held stationary.
Clutches — Direct
The direct clutch is a multi-disc clutch made up of steel and friction plates.
  • The direct clutch is applied with hydraulic pressure and disengaged by return springs and the exhaust of the hydraulic pressure.
  • It is housed in the direct clutch drum.
  • During 4th, 5th, and reverse gear application, the direct clutch is applied transferring torque from the forward clutch cylinder to the direct clutch drum.
  • This action causes the forward sun gear to drive the pinions of the low/reverse planetary carrier.
Clutches — Forward
The forward clutch is a multi-disc clutch made up of steel and friction plates.
  • The forward clutch is applied with hydraulic pressure and disengaged by return springs and the exhaust of the hydraulic pressure.
  • The forward clutch is applied in all forward gears.
  • When applied, the forward clutch provides a direct mechanical coupling between the center shaft and the forward ring gear and hub.
Clutches — Coast
The coast clutch is a multi-disc clutch made up of steel and friction plates.
  • The coast clutch is applied with hydraulic pressure and disengaged by return springs and the exhaust of the hydraulic pressure.
  • The coast clutch is housed in the overdrive drum.
  • The coast clutch is applied when in 1st, 3rd, D4, and reverse positions.
  • When applied, the coast clutch locks the overdrive sun gear to the overdrive planetary carrier, thus preventing the one-way clutch from overrunning when the vehicle is coasting.
    • This allows the use of engine compression to help slow the vehicle and provide engine braking.
Clutches — Intermediate
The intermediate clutch is a multi-disc stationary clutch made up of steel and friction plates which are in a module assembly that includes the cylinder and frictions.
  • Applied with hydraulic pressure.
  • Disengaged by a return spring and releasing of hydraulic pressure.
  • Hydraulic pressure is feed through a feed tube in the case worm trail.
  • Uses a bonded piston in an aluminum housing.
  • Applied in during a 2-3 shift event.
  • Transfers torque from the sun gear to the planetary carrier.
  • Torque transfer causes the one way clutch to engage and holds the sun gear from turning, delivering 3rd gear.
One-Way Clutch — Direct
The direct one-way clutch is a sprag-type one-way clutch that is pressed into the center shaft.
  • The direct one-way clutch is driven by the ring gear of the overdrive planetary carrier.
  • The direct one-way clutch holds and drives the outer splines of the center shaft in 1st, 3rd, 4th and reverse gears.
  • The direct one-way clutch overruns during all coast operations and at all times in 2nd and 5th gear.
One-Way Clutch — Intermediate
The Intermediate One-Way Clutch is a sprag type one-way clutch.
  • The Intermediate One-Way Clutch connects the intermediate assembly to the input shell and sun gear assembly in third gear.
One-Way Clutch — Low/Reverse
The low/reverse one-way clutch is a sprag type one-way clutch.
  • The low/reverse one-way clutch holds the low/reverse drum and low/reverse planetary assembly to the case in 1st and 2nd gear.
  • In all other gears the low/reverse one-way clutch overruns.
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
