Question about Garmin Fishfinder 140
Won't go when turned on
When press button to turn on, nothing happens. Battery good and terminals good
97 Suzuki LS 650 Savage won't turn over. Battery is charged to 12 volts, and I replaced the fuses, but still nothing. When I push the starter button nothing happens. No clicks, no lights dimming.
if you can arc and get it to work
what are the battery terminals like... clean and tight
check continuity for the earth chassis to battery neg - terminal wire
also the wire voltage to the starter from pos battery
if that checks out
bench test starter
solenoid not kicking out properly or problem with lazy starter motor
Apr 12, 2017 | Suzuki Motorcycles
Crosley CAWC529PQ1 won't turn on.
First, you'll need to make sure you have the proper voltage at the outlet, and the power cord terminals fit tightly into the outlet slots. Based on your post, you most likely have a faulty electronic control board.
Here is the board to order.
Nov 25, 2012 | Crosley CCW5294W Top Load Washer
I have a95firebird t a turn the key nothing happends no gauges work on the dash nothing lights up but it has a good battery
Make sure the battery terminals are clean! I can't believe GM still won't get off it with this design.No other company has changed to this design,and with good reason.They make jumper cables impossible,and how can you see the corrosion when it happens? Remove the 5/16 battery bolts (black first),and look at the terminal inside the boot.
Oct 14, 2012 | Cars & Trucks
My droid incredible2 won`t turn on. how do i reboot it
Charge the phone for 10 minutes.
Press down the volume up button and hold it and then press the power button for a few seconds . The device will restart.
Dec 16, 2017 | Cell Phones
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
I put the key in and it won't turn engine over . I think the wireless control module is bad.
Do you have another key ? Try that one and see what happens. Sounds like your old key fob is not making contact with the pcm.have it cheched out
Dec 04, 2017 | 2008 Chrysler 300
Press power button nothing happens
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 27, 2011 | Olympus Cameras
Polaroid A500 digital camera pressed ON button, nothing happened with new AA batteries and SD card
Nov 25, 2011 | Polaroid Cameras
I have a 95 buick-new battery-turn key & nothing happens-won't turn over&where is the starter located
The starter is where the engine joins the gearbox, usually on the engine side. Check that he wiring it connected at the starter and the ingnition switch. Make sure the battery terminals are good and clean and tight. Otherwise the starter solinoid may be faulty, or the starter itself.
Jul 19, 2011 | Buick Lucerne Cars & Trucks
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
Garmin Fishfinder 140 Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
