I have Samsung laptop N150 plus Model no NP N150 JP0AJO Bios version -02KY I already says my bios has been beeping countinue I try everthing changed the window and defreg the8 hard disk but result is nothing and also my keypad is not working now I decided to update the bios so can u plzz tell me how I updte my old bios version 02Ky
  • 1,087 Answers
First thing we need to know is what beeps are being heard? Each computer sounds 'beeps code' to tell you where the problem is; like 3 short beeps, or 1 long 1 short. The more you run it at present the more harm you can be doing
Posted on Feb 10, 2014
Nitrotrike
  • 589 Answers
SOURCE: N600C Bios Update
You can make a bootable cd of the flash image and update the bios that way.
Posted on Jan 20, 2008
danasaur
  • 77 Answers
SOURCE: Toshiba Laptop A60-S166 fdisk won't recognize hard disk?
Hmmm. Unusual report, "secondary optical disk". Sounds like you have a primary and secondary IDE setup. Something desktops had, but rare for laptops. Because of this, I would try setting the HD to "master". Most IDE HDDs have some extra pins beside the IDE pins, 4 or 6 pins in a separate compartment, same side as IDE jack. These are for choosing "master", "slave", and (default) auto detect. To find out which pins must be connected, look for a diagram on the lable or side of HDD. If none there, look up the specs on your HDD at the manufacturer's website. If all fails, It does not hurt to use "trial and error" on these pins. Either BIOS will be happy, -or ignore the setting. Try again until you find the right one. You need a small jumper to try this. If you are VERY careful not to wrap more than two pins, you can do this with a single wire from a copper stranded wire. Use hemostats and clip the excess off clean. Use a magnifying glass to verify it only touches (connects) two pins.
Personally, I would try THIS first, but it will cost you a bit of money... Buy an external IDE HDD case, with USB connector, insert your HD, plug it into a desktop PC, mount it, and use FDISK there. Always better to format a 2.5 inch drive via ext methods. Avoids funky BIOS corruptions, wacky 8mb Toshiba "recovery partitions" and MBR viruses. Also avoids the LBA limits many older laptops have, if YOU format the drive externally. This can also be the only problem. Not jumpers, but format methods. If the laptop is older than 3 or 4 years, I would suggest restricting ALL partitions to FAT32. Maybe C, D and E. Afterwards, the external USB case is a GREAT device to have, for exporting/storing large files from your laptop.
Let me know how it goes
Posted on Feb 11, 2008
Exidous
  • 63 Answers
SOURCE: Arrow keys do not work in Bios
try the page up and page down keys
Posted on Oct 03, 2008
sodeep
  • 3267 Answers
SOURCE: HOW TO UPDATE BIOS
Go to this site: http://h10061.www1.hp.com/ccsearch/search?pname=Compaq+Presario+V3000Z+CTO+Notebook+PC&opname=Compaq+Presario+V3000Z+CTO+Notebook+PC&qry=BIOS+update&submit.x=0&submit.y=0&method=prodFinder&enc=UTF-8&ctry=us&lang=en&dlc=en&sni=3180330&search=0 and update your BIOS if & only if you are facing any problems during normal operation, otherwise do not do so unless prompted to!!!!..sodeep
Posted on Mar 19, 2009
  • 4961 Answers
SOURCE: Reset BIOS password for SAMSUNG NP-SF510 LAPTOP
BIOS passwords can be reset or removed in two ways:
1. using software 2. using hardware.
I would first try resetting or removing using software, here are two software apps to reset or retrieve BIOS passwords.
!BIOS - is a PC BIOS toolkit offering password removal/decrypt and BIOS settings modification/backup/restore.
You can download it here:
http://www.syschat.com/download120.html&act=down
CmosPwd - Cmos password recovery tools
http://majorgeeks.com/CmosPwd_d239.html
You will need to create a bootable Dos, or Linux or NT cd in order to run them.
Good Luck!
Posted on Sep 04, 2012
How to change, bypass, the HDD password on Samsung Model NP 300E5E
Samsung bios password removal - YouTube
? 0:48
https://www.youtube.com/watch?v=QSiUFFWQUOI
Oct 3, 2010 - Uploaded by ScruffyLionTv
Hey guys this is a password removal service free of charge just ... maybe the password is changed, becouse i remove hdd from laptop, ... Samsung Model No: NP300E5C-A011N SN No. ....Samsung NP-R519-JA06ZA 01921269501D289221 .... How to:Samsung Q310 BIOS Password reset / clear cmos ...
Nov 19, 2015 | Cars & Trucks
Samsung n150 plus press f1 to continue
go into bios and disable everything related to stop of failure this will prevent stopping for any f keys
Jun 22, 2014 | Samsung N110-12P Notebook
My samsung n150 plus keyapd is not working properly
It sounds like a key gets stuck on your keyboard, which keeps sending signals to your computer; especially as it seems fine using an external keyboard. When the laptop is off, try typing on each key a number of times, especially the 'suspect' ones, m and 0 (?)
Have you spilt Coke or coffee on it at any time??
Feb 10, 2014 | Samsung Computers & Internet
Startup 6 beeps
Probable Causes
Error
Beep Codes
Defective system board.
Memory refresh failure.
Faulty DIMM or defective system board.
Error occurred in first 64 KB of main memory.
Faulty DIMM.
Read or write error occurred in first 64 KB of main memory.
Timer on system board malfunctioned.
Defective microprocesor.
Microprocessor error.
5
Gate A20 failure.
6
Defective microprocessor.
Microprocessor-execption interrupt error.
7
Missing or faulty video adapter.
Video memory read/write error.
8
Corrupted system BIOS program or defective system BIOS chip.
ROM checksum value does not match value encoded in system BIOS.
9
NVRAM shutdown register read/write error.
10
Defective microprocessor or cache card.
Cache memory error.
11
Faulty video adapter.
Video adapter failure.
12
Loose video cable connection or defective video cable.Faulty video adapter.
No monitor connected.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
I just purchased a brand new battery for my samsung NP-N120 netbook but the netbook doesnt recognize the battery why is that?
Try installing a new battery manager program from the following link:
http://www.netbookfiles.com/2217/samsung-n120-easy-battery-manager-windows-732bit-4002/
System BIOS reads hardware and may need updating, look for updated BIOS software on the manufacturers website: http://www.samsung.com/uk/support/model/NP-N120-KA01EE-downloads
To check your BIOS version: start>control panel>system and security>system. In the left pane, at the bottom, choose; performance information and tools>advanced tools>view advanced system details in system information. Follow instructions carefully when updating BIOS.
If the update is not successful, you may render the machine useless and have to fit a new motherboard.
Mar 29, 2012 | Samsung N120-12GW Netbook
My digital livecam on my samsung N150 is not working.. I am not able to find the software for it on my computer.. it seems like it has been erased.. how do i find the new program or software?
Hi "Roda 918"
here I am attaching the link for your  laptop camera driver , please download and install to work your camera properly,
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_HK_EN&CttFileID=3196312&CDCttType=DR&ModelType=N&ModelName=NP-N150P&VPath=DR/201009/20100912164915468/Camera_ver.345.2001.4004.3_FW.zip
also if you want to get all your samsung drivers and applications you can find it all from the below link
http://www.samsung.com/hk_en/consumer/computer-peripherals/notebook/netbook/NP-N150-KP01HK/index.idx?pagetype=prd_detail&tab=support
Please never forget to rate me if it works....Thank you Ruba...
Aug 27, 2011 | Samsung N150 (36725723009) Netbook
Hi sir i have my samsung n150 laptop i cannot get wifi driver for win xp
hi
just try this link
http://www.samsung.com/in/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=1401&prd_mdl_cd=NP-N150-JA01IN&prd_mdl_name=NP-N150&srchword=NP-N150
Apr 21, 2011 | Computers & Internet
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
