Question about Polar S1 Foot Pod
Does not sync with ft80. turns on, but no data reflecting upon upload
I can turn the s1 on, it blinks during the run, but no data syncs with my ft80.
Why am I getting no emails on my tablet
To control sync settings for the device, follow these steps:
Android 4.0 / 4.1 / 4.2
  1. From the Home screen, open the Settings menu.
  2. Under Personal, touch Accounts & sync or Accounts.
  3. To turn on or turn off Auto-sync
    • Touch the switch at the top of the screen.
      HTC Sense Samsung TouchWiz
      1. From the Home screen, tap the Menu key.
      2. Tap Settings.
      3. Tap the Connections tab.
      4. Tap Data Usage.
      5. Tap the Menu key.
      6. Check/uncheck Auto sync data.
  4. Touch an account to adjust settings, turn on, or turn off sync.
    • MobileLife Contacts
    • Google (appears if set up)
    • Microsoft Exchange ActiveSync (appears if set up)
    • Others, depending on apps installed
  5. To synchronize all accounts manually, touch Sync all.
  6. Press the Home key.
Android 2.1 / 2.2 / 2.3
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Accounts & sync.
  4. Under General sync settings, turn on or turn off:
    • Background data
    • Auto-sync
  5. Under Manage account, touch an account to adjust settings, turn on, or turn off sync.
    • Exchange ActiveSync (appears if set up)
    • MobileLife Contacts / T-Mobile / T-Mobile Contacts
  6. To synchronize all accounts manually, touch Sync all.
  7. Press the Home key.
Android 1.5 / 1.6
  2. Touch Settings.
  3. Touch Data synchronization.
  4. Turn on or turn off Auto-sync.
  5. Touch an account to turn on or turn off sync.
    • Gmail
    • Calendar
    • Contacts
  6. Touch Menu.
  7. To synchronize all accounts manually, touch Sync now.
  8. Press the Home key when sync completes.
Feb 19, 2015 | Samsung Galaxy Cell Phones
How do i connect my fitbit device to my verizon tablet.
Syncing Your Data
  • The Tracker will upload your data every 15 minutes provided you are within range of any plugged in base station (about 15 feet for direct line of sight), the computer is on and not in sleep or hibernate mode, the software is installed and running, and you have an active internet connection.
  • While out of range, the Tracker will look for a base station every minute until it syncs your data, after which it will wait 15 minutes before searching again.
  • You can see when the last successful sync occurred by viewing your main page at www.fitbit.com. Near your profile picture, you will see Synced with a time and date of your last sync.
  • If you want to force the Tracker to upload its data, place the Tracker on the base station.
  • While we recommend you sync your data regularly, the Tracker has the ability to store 7 days' worth of detailed, minute by minute data. It will store summary data (calories, distance, and steps) for the trailing 30 days. If you wait longer than 7 days before syncing, you will not see your minute by minute graphs (except on the most recent 7 days).
  • Your Tracker is able to sync from multiple computers, as long as each computer has the Fitbit software installed and a working base station is plugged in. You don't need to physically connect the devices. Simply down load the app and upload your info.
Sep 17, 2014 | Fitbit Ultra Tracker
Sky drive
Have you went to your account and tried to turned off sync? That way you could choose what to upload and when. I don't know what the setting s are for sky drive, I use a different backup service, but you should go to your account dashboard and look for syncing choices. If that fails, maybe contact MS and ask them?
Mar 30, 2014 | Microsoft SkyDrive
The brookstone stunt copter and remote donot sync
It would not sync. solution was to assume poor technical writing. step zero. turn the controller off. step one. plug in the battery to the copter. step two. QUICKLY turn the controller on. if you miss this small window of time, it is going to fail. The copter light blinks fast during this period, and if it slows the blink rate, then you have waited too long.
Dec 13, 2012 | Shuttle 9094 Emax Remote Control...
How do I sync Notes with my Mac laptop and my iPhone using Mountain Lion?
Hi Rachel,
In order to sync your Notes between your Apple devices, please use the following steps:
  • Go to your iCloud settings and sign up for an @me.com email address.
  • Once you have an @me.com email address, write a note in the Notes app on your iPhone.
  • Go to the iCloud website and open up the "Mail" application
  • Underneath all of your email folders (Inbox, Sent, etc.) there should be a folder called "Notes"
  • Open that folder and read your note!
Aug 01, 2012 | Apple OS X 10.8 Mountain Lion
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
    Standard Mode Synchronization
    Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Jan 27, 2011 | Nintendo Wii Console
Console does not respond to all remote actions, ie no cursor on screen,only the minus , home , and plus buttons work i have tried several remotes and changed the sensor bar.
I would try to re-sync the controller to the console.
1. Power on Wii
2. remove battery cover from wii remote; press sync button on remote, will cause LED's on remote to blink.
3. Press the sync button on the console (it is located in the memory card holder on the front of the console)
4. The remote is connected once the LED stops blinking. The lit LED indicated what player # the connected controller refers to.
If you are still having trouble then delete the configuration info first and then re-sync the controller to the Wii.
Do this by holding the SYNC button on the console for 15 seconds after turning the unit on (once you see the health and safety screen). After you do this you will need to re-sync the controller individually.
It also warns of bright light sources like sunlight near the sensor bar, highly reflective surfaces (mirros, etc.) behind the sensor bar, sources of infrared radiation (portable heaters or fireplaces) or radio interference from cordless phones, cell phones, etc. as possible causes of interference. See pages 22, 32, 34 of your Wii owner's manual for full information, or call 1-800-255-3700 if you are still having difficulty.
Dec 31, 2010 | Nintendo Wii Console
I cant sinc my i phone as it says unable to connect to i tunes store.
Please follow the steps below to resolve your sync issues which applies to iPhone, iPad, or iPod touch. If you make changes during any of the steps below, try syncing again with MobileMe on your iPhone, iPad, or iPod touch.
  1. If you are syncing calendars or contacts, view the data on MobileMe Calendar or MobileMe Contacts. If the data does not appear to be correct there, the issue is not with your device. If you are syncing using a Mac, see this article for more information. If you are syncing using a PC, see this article for more information.
  2. Make sure your device is up to date with the latest software. To make sure your device is up to date, connect it to your computer, open iTunes, and click "Check for Update."
  3. On your device, make sure you are able to connect to the Internet. For example, open Safari on your device, then browse to http://www.apple.com . MobileMe requires an Internet connection to sync. (A 3G or WiFi connection is recommended during setup or when following many of the steps below; they may require several minutes via an EDGE connection.)
  4. Confirm that a sync is not already occurring. If a sync is occurring, the activity spinner (in the status bar) will display while looking at Safari Bookmarks (if Bookmarks are currently syncing), Calendar (if calendars are currently syncing), or Contacts (if contacts are currently syncing). If a sync is occurring, wait for the sync to complete, and then see if your data is up-to-date.
  5. Make sure you are looking at your full set of contacts or calendars. When configuring your MobileMe account in iOS 3.1 and later, you will have a choice to Merge or Don’t Merge your data. If you choose Don’t Merge, your MobileMe data is kept separate from the data that was already on your device. In Contacts/Calendars, tap the button in the upper left corner until you are able to see all Groups or Calendars, and verify that you are looking at your MobileMe data.
  6. Confirm that you are able to get your MobileMe Mail on your device. If you receive an alert message when attempting to get your MobileMe Mail, your account may not be configured correctly, or you may not have a reliable internet connection. If the alert message is about your username or password being incorrect, go to the next step.
  7. Verify your MobileMe account is configured correctly on your device:
    1. On the home screen, tap Settings > Mail, Contacts, Calendars.
    2. Tap Fetch New Data, and make sure Push is turned On. Tap Mail... to go back one screen.
    3. Tap your MobileMe account.
    4. Tap Account Info and check the Address field.
    5. Verify that your address appears correct (it should appear as your MobileMe email address, such as membername@me.com or membername@mac.com). If your account does not appear as expected, see the “Delete and re-add your MobileMe account” under the Advanced Troubleshooting section below.
    6. If you received an alert about your username or password during step 6, delete and re-enter your MobileMe password, and then check your Mail again. If your still receive the same message, try logging into www.me.com. If you are unable to log in, see this article.
    7. If your account does appear to be entered correctly, go back one screen and confirm the sliders for the data that you want to sync are set to On.
  8. Verify that your device is connected to the MobileMe service. To confirm this, visit http://www.me.com/find from a computer. Because Find my iPhone relies on the same connection as MobileMe Sync, your device should be listed as "Online" for as long as it has an active Internet connection. If the device does not appear as expected, please see this article about troubleshooting Find My iPhone.
  9. Restart your device: Hold the power button until "slide to power off" appears. Slide to power off. After it is off, press the power button to turn it back on.
  10. Wait an hour and try again. Apple may temporarily disable an account from syncing with MobileMe if it is determined that an account may be taking longer than normal to sync. By waiting an hour and trying again, this allows for the previous sync to complete. If you find your account encounters the issue again, go to the Advance troubleshooting section.
If the above steps do not resolve your issue on your iPhone, iPad, or iPod touch, you can try these advanced troubleshooting steps:
Turn all syncing off and then back on
From the home screen, tap Settings > Mail, Contacts, Calendars, and then tap your MobileMe account. Tap the sliders off for each account that your are syncing. If prompted to do so, tap "Keep on My iPhone" (or iPad/iPod touch). Turn your device off and back on, then re-enable syncing. If prompted to do so, choose Merge with MobileMe. Wait a few minutes, and try syncing again.
Isolate the issue to a specific data type
If the above did not resolve the issue, once again turn off all syncing, and then test each data type one at a time. For example, if Contacts syncs successfully, but Calendars does not, focus your troubleshooting on Calendars.
If you have isolated the issue to either Contacts or Calendars that are not syncing successfully (one works, the other does not), see this article recommendations about how to clean up that data on your Mac or PC, as it is likely causing the issue.
If none of the above steps resolve the issue, make sure you have a copy of all Contact, Calendar, and Bookmark data on your device saved on your Mac/PC. From the home screen, tap Settings > Mail, Contacts, Calendars, and then tap your MobileMe account. Tap Delete Account. (If prompted to do so, choose "Delete from My iPhone" (or iPad/iPod touch). Restart your device. After it restarts, on the Mail, Contacts, and Calendars screen, tap Add Account > MobileMe, and set up your account again.
Aug 15, 2010 | Apple iTunes
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
Sync only goes one way -- from palm to computer
Check the hot sync manager to set the flow of info from desktop to device during the initial restoration of data to your Palm. Afterwards, once you have all your info restored, you'll want the device(s) and desktop calendar to update each other, so make sure your settings in the sync manager reflect that, otherwise you'll continue to have one schedule overwriting the other.
Hope that helps. Let me know how you make out.
Jan 19, 2008 | Palm Z22 Handheld
Polar S1 Foot Pod Logo
Top Polar Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Jerry Greenberg
Jerry Greenberg
Are you a Polar Exercise and Fitnes Expert? Answer questions, earn points and help others
