Question about Garmin Fishfinder 140
Not working On button is pressed and nothing happens. Battery good and terminals good
Replaced clutch and starter and won't start power in battery all works lights ect when I press starter button nothing happens
Hi Martin,did you reconnect the ground cable? It normally goes under one of the bell housing bolts.
Mar 19, 2015 | Power Motorcycles
Press the starter button nothing happens 1983 Honda CB 1100R
Hi, Anonymous before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Starting issue push the start button and nothing happens
GL1100 Starter button no respense doesn start
Honda CB1100R Manuals Literature eBay
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Feb 22, 2013 | 1983 Honda CB 1100 R
Hi My daughters Vtech Camera just stopped working suddenly have tried to change the batteries Put brand new one in the right way up and there is nothing happening at all have tried to press reset button...
Try the battery on another appliance to confirm the charge capacity or make sure there is voltage and current available on the battery. If so check the terminals on the camera, open and clean the battery terminals. If not there is a fault within which need that you need to open the camera. it can be a fusible link, fuse or a protection on the main board.
Feb 09, 2011 | Vtech Kidizoom Digital Camera
No lights come on and nothing happens when i press the starter
the yellow or yellow and white wires have come apart under tank simply remove tank follow the wires from right hand switch block should be a black connection block and yellow and yellow and white wires are the old type bullet connectors check for corrosion green deposits reconnect wires yellow to yellow and yellow/white to yellow/white id use some electrical tape to insulate further also helps to stop them working loose again when handle bars are turned switch on the ignition b4 putting tank back on press start button it will start trust me lol
May 19, 2010 | 1997 Suzuki GSX 600 F (Katana)
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
When i press the unlock or lock button on my car key, nothing happens(i have fitted in a new battery in my key)
with your key in hand disconnect the veichle earth terminal on the battery, while depressing the open door button on the keyfod at all times reconnect the battery earth while holding button down, after a few seconds you should hear the doors opening/closing.then relese the button,tighten the earth terminal on the battery and that should be you..
Jan 30, 2010 | 2000 Ford Focus
Microsoft wireless mouse 3000; put in new battery, still nothing
Your problem lies only in mouse. All procedures followed are correct, but take a close look at the bottom of mice where the receiver is placed when not in use, look for a tiny thin button that protrudes from one of the sides, it has to be depressed while receiver is out, it might be stuck, try to press it down gently a couple of times, it must come out. If it doesn't work, take off battery, now press down mentioned button and release it immediately upon inserting back the battery. Hope will work ok. Good luck!! Chawah.
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Sometimes middle of process, it suddenly stop. and i try to trun off and press start button again, but nothing happen.normally if i press start and it shows green light but it didn'nt. it seems start...
IT SEEMS TO ME LIKE THIS SWITCH HAS WEAK CONTACTS
OR WEAK TERMINALS .
THE SIMPLE CASE IS USING SMALL PLAYER AND TO SURE THE TERMINALS IN GOOD CONDITIONS
Jun 18, 2009 | AEG Washing Machines
Won't power up
Check the battery terminal and make sure there's a
good contact between battery and terminal.
May 15, 2009 | Cameras
Garmin Fishfinder 140 Logo
41 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
