Question about Hitachi 168589 DVD Player/VCR
ERROR MESSAGE i RECORD A dvd-r WHICH PLAYS BACK FINE ON THE COMPUTER, BUT IN THE hITACHI dvd/vhs i GET AN ERROR MESSAGE TO REMOVE THE DISC. wHAT IS THE PROBLEM?
    Novelist:
  • 233 Answers
After recording a disk, when the program is ready to "Finalize" then self eject the disk.
There is a statement that asks something like this "Do you want this disk to run on other devices, or just this computer?
You must put a check in the "Run on other Devices"
You may have checked it incorrectly as a Default somewhere within the program Options, to just "finalize and eject" or to just "run on this computer only".
Posted on Oct 26, 2007
  • 328 Answers
Your DVD may not support the codec that you used to record with. There are many formats like DIVX, Mpeg, and Mov files. Your system must support the format that you recorded or it will not work.
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
Cannot format a dvd-rw disc or record to the disc.
Unless you posted this question in the wrong category, you can't use the Sansui VRDVD4000 to record to DVD. It is a DVD player only, not a DVD burner. It will play and record VHS tapes, but with DVDs it will only play them.
To record to a DVD, you would need a DVD burner. Many modern computers include a DVD burner, so maybe either your computer or someone you know's computer has a DVD burner.
Dec 30, 2009 | Sansui VRDVD4000 DVD Player/VCR
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
MRV700VR
EXT1 is not an error - that message means that the dvd player is on input "EXT1" - so it is trying to display whatever is connected to EXT1 in the back of your DVD player, whether it is a cable/sat box, another vhs player, etc. The message may be getting displayed for a number of reasons - but, if you put in an incompatilbe/unfinalized disc type, and it is not able to play that disc, it may default to EXT1 b/c it is searching for some type of usable signal.
The MRV700VR is only compatible with certain discs types - and the disc types that you are trying to insert must also be finalized discs. I would reccomend only using the compatible disc types listed in your user's manual - some of them are getting harder-to-find. 16x discs are very iffy with this machine. 8x discs are best.
I have the full user's manual, so I can give you any more details that you request.
-Tha Mp3 Doctor
Mar 18, 2009 | Philips MRV700VR DVD Recorder/VCR
DVD does not play on other players or computer
Hi and welcome to FixYa,
Your description indicates that the last step in the DVD recording has not been performed on these discs that were recorded on the Magnavox. This would be "finalize" or instruct the Magnavox that no other files would be written/recorded on the current disc. Thereafter, the Magnavox would complete the DVD disc making it playable in any other player. Normally, finalization would take a bit of time to complete.
Pls post back how things turned up. Good luck and thank you for using FixYa.
Feb 02, 2009 | Philips Magnavox DVD/VCR Dual Player
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
ERROR MESSAGE:
If these disks have not been finialized then they will not play on the dvd player. Turn your computer on and see if they will play. If they will then you will need to the dvd palyer finialize them. I hope this helps you. If not get back to me and then we can try a different way.
Aug 15, 2008 | Hitachi 168589 DVD Player/VCR
Can't view DVD's burned from the tv on a DRC8335 RCA DVD recorder
If you do not finalize the disc then you can not play it back. Go back to your instruction manual and look under 'setting options'. There should be a choice to 'finalize disc before ejecting'. The recorder will not finalize a disc until it knows when you are done recording, so you have to tell it somehow.
Jan 02, 2008 | RCA DRC8335
I have recorded (on to dvd-rw) my old VHS tapes. They won't play on computer
The PC requires a compatible DVD player software! What are you trying to play the DVD with?
Sep 28, 2017 | Hitachi DV-RX5000U DVD Recorder
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Hitachi 168589 DVD Player/VCR Logo
117 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
