Question about Dell Precision M4500 Notebook
Unable to access SD card in card slot - Dell Precision M4500 Notebook
2 Suggested Answers
  • 27 Answers
SOURCE: i have a dell inspiron
You will need to put the micro card into an adapter first before it will fit in your SD slot. This what it will look like.
Posted on Jan 06, 2011
Where is sd slot on computer
The Acer 5315 Notebook doesnt have a SD Card slot to my understanding.
Jan 09, 2013 | Acer Aspire 5315 Notebook
Dvd recorder unable to view recordings says no sd card what is this please
Sd card is the memory card u stick into the slot that said Sd card or memory card to the right side or left side edges of the unit device.
Mar 30, 2011 | Televison & Video
LG Ally Android phone says it's checking the SD card for errors. Can't access SD card.
you can try plugging the SD card into your computer with an SD card adapter and see if you can access your files.
You may have to format your SD card if you cannot access your files this way. from the phone go to settings, SD Card - phone storage (some phones its labeled different) From there you can format your SD card, depending on your phone you may have to choose Unmount SD card first.
If you continue to receive errors or are unable to format the card, it is most likely that the SD card is bad and needs to be replaced.
Mar 21, 2011 | LG Ally Cell Phone
UNABLE TO ACCESSMY 4GB MICRO SD CARD
Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
I cant seem to find my SD card slot on my Aspire 5515 basic vista laptop either i dont have one or i need to buy somthing.so really there is two probs 1) Were is da SD card slot and 2) if there isnt one...
The full specification of your laptop is located HERE. It shows that you do not have any card (mini or SD Cards) slots.The only option left in order for you to use and access any memory card is to buy an "external" USB-type Card Reader. There are 3-in-1 and 5-in1 Card Readers that can be connected via your USB port. In these card readers, you can plug in your memory sticks or memory cards and your computer can then access it.
Feb 09, 2010 | Computers & Internet
SD card slot access Win7 Networked printer
INSTALL THE COMPLETE APPLICATON SOFTWARE OF C3100. YOU WILL GET THE OPTION THERE
Sep 12, 2009 | HP Photosmart C3150 Printer
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Sd card jammed in sd card slot
This may sound bad, but I promise it isn't. Have you tried removing the SD card with a small pair of needle nose pliers or even some twizzers? It sounds like the spring mechanism failed, so your only solution now is to pull it straight out, a little force and it should come right out. There are no pins to bend on an SD card.
Apr 21, 2009 | Computers & Internet
Card format problems
The first thing you will have to check the card. There is slot on the card that contains a switch. This will lock the card so that it is write-protected. This will cause the unsupported card error.
If the card looks fine, try a card reader just to confirm that the card has not been corrupted.
If the card is functional and you can read its contents from the PC or another SD-slot device, then the issue is your camera. The slot contains thin copper prongs that comes in contact the copper surface on the back of the SD card. If the prongs are bent or damage, then the camera cannot read your card.
Aug 27, 2008 | HP Photosmart M527 Digital Camera
How does the 5 in 1 card reader work on the Acer Aspire 5920 laptop? I am not sure how to get the SD card into this slot. Thanks
There should be 5 slots. Near each slot has the trademark of the card that the slot is for. If you are unable to identify the trademarks or there aren't any ways of finding which slot is which, then try each slot. Do not force your SD card into the slot. There should be only one slot that is the perfect fit for the SD card. Just slightly change the angle of the SD card until it slides in. The SD card has little to no extra room so it will take a little while to get the SD card in. Also the slot is spring loaded so you should here a click when it is in correctly.
If you have trouble, just keep trying and don't force it in. Trust me that it will fit if it is the right slot. Sometimes I get my SD card into my Wii or laptop in under a minute and sometime I have to mess with it for over 5 minutes (the angle of the stand for the Wii doesn't help at all).
Once you get the SD card in correctly, it will show up as a drive in "My Computer" but Windows XP and Vista have normal alerts with a "new hardware found" tone. Think of it as an USB flash drive that is smaller and goes into a specific slot.
When you are done, just push the SD card in and the slot should eject the card so you can pull it out.
Good luck and I hope you get it in.
Aug 15, 2008 | Acer Computers & Internet
Dell Precision M4500 Notebook Logo
11 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
