Question about Winter Sports
Polaris 600 cuts out at hi rpm
My Polaris 600 cleanfire sdi starts and runs fine until it gets up to about 60 mph. At that point the engine cuts out. If I back off the throttle it runs fine if I keep its below 55 mph (approx. 7000 rpm. any ideas ?
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
Check your Air Filter, clean it out, check for obvious blockages. Change the filter if it looks well used (look for excessive dust or color change on the inner part of the filter) or obvious wear.
Check for other blockages around the air filter inlet.
Check the spark plug, just change it for a new one so that eliminates that possibly.
Check your fuel filter and replace if needed.
Check the fuel tank for corrosion or dirt in the fuel. Empty it out, Clean it and add new fuel, be sure you have the correct fuel.
Check your Air / Fuel mix adjustment screws on the carburetor.
Hope that helps a bit
Good Luck
Posted on Feb 10, 2014
I need a repair manual for 2009 Polaris swichback sled 600 HO cleanfire please.
Contact Polaris directly to request the repair manual..
Sep 26, 2017 | ATVs
Start up idle is slow below 1050 rpms and sounds like going to stall while idling. Runs fine otherwise.
How to adjust your Polaris Snowmobiles TPS. - YouTube
? 6:05
https://www.youtube.com/watch?v=aEPx7OsywNk
Dec 11, 2009 - Uploaded by PolarisRich
A quick video on how to adjust your Polaris Snowmobiles Throttle ... TPS cause this? it seems like it hits top rpm, it runs flawlessup to the ... Would this work on a 2011 Polaris pro rmk 800?? ... I have a 2006 Polaris Fusion 600 h.o. It seems to bog out when u first start ... Sounds like its a carb or clutch issue!
2011 Pro RMK 800 Top End Bogging [Archive] - SnoWest Snowmobile Forum
www.snowest.com/forum/archive/index.php/t-298871.html
Jan 30, 2012 - 52 posts - ‎33 authors
[Archive] 2011 Pro RMK 800 Top End Bogging Polaris: Pro-Ride. ... Sled is a 2011 ProRMK 800 155, 1700 kms, MBRP can. ... problems with bogging at every rpm and roughidle, I am running 91 from .... fuel filter yet?...almost sounds like your fuel pump can't keep up with ..... I am running a 2010 660 CFI-4. 2010 dragon 155 RMK electrical problems
Feb 3, 2013
Polaris update
100+ posts
Nov 15, 2009
~~The Official Phazer Thread~~
100+ posts
Sep 12, 2009
M1000 Hiccups on the Bottom
100+ posts
Jan 28, 2008
More results from www.snowest.com
Jan 12, 2016 | Polaris 2010 RMK 800 Dragon 163-Inch
I have a 2004 polaris sportsman 500 when it gets hot it cuts off and back fires
Does the cooling fan ever run when the engine is hot? If not, you may have a problem with the fan thermostat.
For the record, spray carburetor cleaner does no good if it's sprayed on the outside of the carburetor with the engine running. That's not what it's for.
Jul 29, 2014 | Polaris 2004 Sportsman 500 H.O
Slow ground speed
or low geared all the way around..
Mar 08, 2014 | Polaris ATV
Can anyone tell me about Polaris Rush Pro?
Hello Rajendra, Rush Pro is an appreciable product by Polaris India. It is coming with lots of exciting features like-
Pro-Ride progressive-rate rear suspension
Pro-Ride chassis
600 Cleanfire engine
Race-Proven front suspension etc.
For more details, visit:
Rush Pro Snowmobile Features Buy snowmobile in India Snowmobile dealer...
Feb 28, 2014 | Polaris ATV
Runs fast 100 mph for 5 minutes. heats up and goes down to 60 mph. cool off 5 minutes back to normal
Check your Compression, once the engine gets to temperature, you are EXPANDING the Metal and losing compression.
It could also be the PRIMARY CLUTCH, If you are experiencing a Primary Clutch Failure, the Springs inside will be effected by the HEAT.
QUESTION:-
What is the Engine RPM when you are doing 100 and when doing 60?
Is the Engine RPM IDENTICAL? If RPM is the Same, you have a Primary Issue, if the Engine can't get out of its own way, then you have a Compression Issue
Jan 28, 2014 | Polaris 2009 Trail Touring DLX
My 2004 700 sportsman runs great and then cuts out at 20 mph. If I take my thumb off the throttle, it'll recover and run great until 20 mph. what gives???
Your carb. isn't getting enough fuel when the demand increases as you go faster. Begin by getting a can of a carb. cleaner, like seafoam which you add to the fuel, one ounce per gallon. That will clean your carb while u operate your sportsman and hopefully solve your problem. If that doesn't clear it up then the carbeurator will have to be rfebuilt.
Jul 05, 2009 | Polaris ATV
Engine won't run properly
sounds like its running rich. check your float height and then lower your main jet needle a notch
Dec 04, 2017 | Polaris ATV
Winter Sports Logo
389 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
vtrktrmn
Are you a Winter Sport Expert? Answer questions, earn points and help others
