Question about Brookstone Pocket Projector for iPhone 4 Devices
Brookstone pocket projector wont turn off
The projector has a blue light above the on and off switch. The blue light wont stop blinking and wont shut off!
I'm having the same issue. it 1st started with a No Signal error. then this started...ugh!
Posted on Mar 02, 2014
Projector turns on, displays Brookstone logo and then turns off. It's not the power; the unit is plugged in.
It is most likely your lamp. If you replace the lamp then you need to reset the lamp timer back to zero or it will keep shutting off on you.
Jan 15, 2016 | Brookstone AAXA 50 Lumen HDMI 720p P3 Pico...
There is a blue line when plugged into laptop
I had the same problem. The projector works wonderfully connected to my iPhone (with an adapter), and connected to other kinds of laptops, but not with mine. Apparently the projector is not compatible with every laptop. I had to connect my projector to my laptop via a Netgear PTV1000 streaming player in order to use it.
You connect to the player wirelessly. Then use the HDMI cable to connect the player to the projector.
Streaming Players
I happened to already have the player so I didn't have to purchase a new device. I hope this helps you.
Jun 28, 2014 | Brookstone HDMI Pocket Projector
Projector blinking blue power light. non stop!
check the lamp Please
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 13, 2014 | InFocus Office Equipment & Supplies
BROOKSTONE HDMI PROJECTOR 801143 DOES NOT CHARGE
The Brookstone manual claims it will fully charge after 3-5 hours, but it takes much longer then that. Mine does not indicate green light, but it seems it stops blinking red when its fully charged. After that it run on power directly from the ac-adapter.
If you keep it connected to the AC-adapter after it have stopped blinking red (do not disconnect it at all), it will start to run on the adapter and will not turn off. You will feel the AC-adapter gets hot while its running, something it does not while regular charging.
If it still dont stop blinking red after having it connected to power for 3 days, your AC-adapter is probably faulty. This happened to me, and after allot of research I found this replacement from a US seller on ebay (only five dollars included shipping).
http://www.ebay.com/itm/251623019268?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Good luck with your projector. It a really cool little thing, but it has some design flaws.
Best regards.
Feb 17, 2014 | Brookstone HDMI Pocket Projector
Acer projector blue light blinks and fan blows and no picture
As far as I can tell this looks like a lamp problem. Unless some of the fans are not able to cycle up tehn it would shut down before it overheats
Feb 14, 2014 | Acer H5360 3D Video Projector 3D
Hdmi pocket projector color off blue displayed as red
I bought 1 today. This evening I tried it with my camera Sony HDR250V And I noted It has the same problem You Have. How did You solve it?
Jun 21, 2013 | Brookstone HDMI Pocket Projector
Our brookstone rover'wifi is not working it's blue light is not blinking
Most likely your batteries are dying. We had this same problem and changed the batteries now it works fine.
Sep 11, 2012 | Brookstone Rover App-controlled Spy Tank...
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
Brookstone Pocket Projector for iPhone 4 Devices Logo
109 people viewed this question
Top Brookstone Office Equipment & Supplies Experts
Jerry Kramer
Jerry Kramer
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
